Subject: Re: SIS3316 or other fast, high-resolution digitizer support
From: Heinz Junkes via Tech-talk <[email protected]>
Date: Thu, 18 Mar 2021 08:20:49 +0100
Good morning Mark,
I have a support for it which I am currently testing intensively under RTEMS and EPICS7 (incl. pvAccess).
It should go into production on Monday. I will put it in git this weekend and you can have a look at it then.
It should also run under VxWorks. Also uses asyn ;-)
Gruss Heinz
P.S. I now use the VMEbus with MVME6100
P.P.S The software that uses the GigE port has been running on Linux for a while now.
> On 18. Mar 2021, at 00:33, Mark Rivers <[email protected]> wrote:
> Folks,
> I am interested in finding out about EPICS support for the SIS3316-250-14 or SIS3316-125-16 digitizers.  These are 250 MSample/s 14-bit and 125 MSamples/s 16-bit respectively.  I saw that in 2015 Heinz Junkes said he had a driver that used the GigE interface on the card.  Is there a vxWorks driver?
> Alternatively are there other digitizers with similar specs that have EPICS support?
> Thanks,
> Mark
Attachment: smime.p7s
Description: S/MIME cryptographic signature
SIS3316 or other fast, high-resolution digitizer support Mark Rivers via Tech-talk
Prev: 8671B Synthesized CW Generator (GPIB) Ernesto Paiser via Tech-talk
Next: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Prev: SIS3316 or other fast, high-resolution digitizer support Mark Rivers via Tech-talk
Next: 8671B Synthesized CW Generator (GPIB) Ernesto Paiser via Tech-talk
