Hey Ralph,
Could there be something I am overlooking when using your script, I am fairly sure I have it setup correctly but still can not get it the client to communicate with all the
IOCs.
Setup is as follows:
Client 192.168.1.50
Client running caget PV1
Env variable CA_ADDR is set to the host ip and CA_AUTO is set to YES
Host 192.168.2.100
Host running 4-5 IOCs (script is in both of the /etc/network/if-up/down.d folders and have been made executable)
Env variable CA_ADDR is set to the client ip and CA_AUTO is set to YES
If I start up the IOCs in different orders the client does not always have access to the all of the IOC pvs. I can run each IOC isolated and client is able to caget the PVs.
Adam
- I don't know anyone who runs multiple IOCs on Windows.
You know me J
Kidding aside, I do run multiple IOCs on Windows. So far I have not needed to access them from another subnet.
Sent: Wednesday, March 17, 2021 11:27 AM
To: Mark Rivers <[email protected]>
Subject: Re: Multiple IOCs on one host Issue
I know.
Alas, I have no clue, and I don't know anyone who runs multiple IOCs on Windows.
On my Windows laptop, I don't have Admin rights.
Ø
That's why it is featured on the how-to page.
I notice that that page does not have an entry for Windows.
On Behalf Of Ralph Lange via Tech-talk
Sent: Wednesday, March 17, 2021 11:05 AM
To: EPICS Tech Talk <[email protected]>
> Sorry wanted to add, or can I just go back to using the IP addresses of the server/client instead of broadcast?
No, you cannot do that. It will only find one of the IOCs on the server if you do that. You either need to use the directed broadcast mechanism or the iptables mechanism.
Out of which the iptables rule is the least invasive, because it is a once-and-for-all change that needs to be added only on the multiple-IOC host, and does not require any other
changes in IOCs, network components or clients.
- Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
- Re: Multiple IOCs on one host Issue Heinz Junkes via Tech-talk
- Re: Multiple IOCs on one host Issue J. Lewis Muir via Tech-talk
- Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
- RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
- Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
- Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
- RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: SIS3316 or other fast, high-resolution digitizer support Heinz Junkes via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
