On 03/18, Manoussakis, Adamandios via Tech-talk wrote:
> Setup is as follows:
> Client 192.168.1.50
> Client running caget PV1
> Env variable CA_ADDR is set to the host ip and CA_AUTO is set to YES
> Host 192.168.2.100
> Host running 4-5 IOCs (script is in both of the /etc/network/if-up/down.d folders and have been made executable)
> Env variable CA_ADDR is set to the client ip and CA_AUTO is set to YES
Those aren't the right environment variables. You might be abbreviating
the names on purpose, but I would recommend you state the exact names
you're using so that no one has to guess what you mean, and also just in
case you've got a typo in any of them.
Lewis
- RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
- Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
- Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
- Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
- Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
- RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
