Hi Lewis,
Env Vars are
Host setup
EPICS_CA_ADDR_LIST=Client IP
EPICS_CA_AUTO_ADDR=YES
Client setup
EPICS_CA_ADDR_LIST=Host IP
I don't think the env variables are the cause in this case but I did try looking at the iptables --list and --list-rules after manually running Ralphs script with sudo and wasn't seeing the added rules from the script. I would think its possible to manually sudo run the script to get them added but I am not that familiar with it.
-----Original Message-----
Sent: Thursday, March 18, 2021 3:02 PM
To: Manoussakis, Adamandios <[email protected]>
Cc: 'Ralph Lange' <[email protected]>; [email protected]
Subject: Re: Multiple IOCs on one host Issue
On 03/18, Manoussakis, Adamandios via Tech-talk wrote:
> Setup is as follows:
> Client 192.168.1.50
> Client running caget PV1
> Env variable CA_ADDR is set to the host ip and CA_AUTO is set to YES
> Host 192.168.2.100
> Host running 4-5 IOCs (script is in both of the
> /etc/network/if-up/down.d folders and have been made executable) Env
> variable CA_ADDR is set to the client ip and CA_AUTO is set to YES
Those aren't the right environment variables. You might be abbreviating the names on purpose, but I would recommend you state the exact names you're using so that no one has to guess what you mean, and also just in case you've got a typo in any of them.
Lewis
- Re: Multiple IOCs on one host Issue Hu, Yong via Tech-talk
- Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
- Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
- RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
- Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
- Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
- RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
- Re: Multiple IOCs on one host Issue J. Lewis Muir via Tech-talk
measComp R3-0 available Mark Rivers via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
