Subject: measComp R3-0 available
Date: Thu, 18 Mar 2021 23:43:58 +0000
Folks,
Release R3-0 of the measComp module is now available.
These are some items from the R3-0 release notes:
  - Changed the method used to specify the device in the constructors and the startup script.
  - The second argument the configuration commands in the startup script (e.g. `drvMultifunctionConfigure()`)
      is no longer a `boardNum` integer , it is a `uniqueID` string.
      - For USB devices the `uniqueID` is the serial number, which is printed on the device (e.g. `"01F6335A"`).
      - For Ethernet devices the `uniqueID` can either be the MAC address (e.g. `"00:80:2F:24:53:DE"`),
        or the IP address (e.g. `"10.54.160.216"`).
        The MAC address or IP address can be used for devices on the local subnet,
        while the IP address must be used for devices on other subnets.
    - There is a new iocsh command, `measCompShowDevices`. This will list all Measurement Computing USB devices
      attached to the computer running the IOC, as well as all Measurement Computing Ethernet devices on the subnet.
  - Added support for the USB-TEMP and USB-TEMP-AI models.
    - These support reading temperature with RTD, thermocouple, thermistor, and semiconductor sensors.
    - The USB-TEMP supports up to 8 temperature inputs.
    - The USB-TEMP-AI supports up to 4 temperature inputs and 4 24-bit voltage inputs.
  - Converted documentation from HTML to Markdown (this document) and ReST (other documentation) at
    https://epics-meascomp.readthedocs.io/en/latest/.
  - Changed the OPI screens to be modular, using subscreens.  This works well because many devices have
    identical functional blocks.  This is much easier to maintain.
  - Removed support for the USB-4303.  This module is obsolete and has not been available for many years.
    The USB-CTR04/08 should be used instead.
The source repository is on Github:
https://github.com/epics-modules/measComp
The documentation is here:
The release notes are here:
https://github.com/epics-modules/measComp/blob/master/RELEASE.md
Prev: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Next: Re: Multiple IOCs on one host Issue Hu, Yong via Tech-talk
Prev: 8671B Synthesized CW Generator (GPIB) Ernesto Paiser via Tech-talk
Next: Job Opening at SLAC National Accelerator Laboratory Zelazny, Michael Stanley via Tech-talk
