Subject: Re: Multiple IOCs on one host Issue
To: "Manoussakis, Adamandios" <[email protected]>, "J. Lewis Muir" <[email protected]>
Date: Fri, 19 Mar 2021 00:29:32 +0000
A few comments and suggestions:
1. You had a typo (I guess EPICS_CA_AUTO_ADDR means to be EPICS_CA_AUTO_ADDR_LIST) although the typo probably does not make a difference in your case.
2. As Mark River said in another thread, you really do not need to set EPICS_CA_ADDR_LIST on the IOC Host.
3.  Ralph's iptables trick is really the least invasive if you or your IT professional colleagues can make it work.
4. Since you have difficulty making the iptables-trick work, you could try this invasive and nasty method which I occasionally used for Lab tests (just for test, not good for massive production):
  1) on the Host 192.168.2.100, in the first IOC's startup script (st.cmd), add this line: epicsEnvSet("EPICS_CA_SERVER_PORT", "5066"). In the second IOC's startup script, add this line: epicsEnvSet("EPICS_CA_SERVER_PORT", "5067"). In the third IOC ...
Basically each IOC has its unique CA Server port instead of the default 5064. After an IOC starts up successfully, type "epicsPrtEnvParams" (or epicsEnvShow) under the EPICS IOC shell to verify your all kinds of EPICS_CA* settings.
  2) on the Client 192.168.1.50, do something like this: export EPICS_CA_ADDR_LIST=192.168.2.100:5066 192.168.2.100:5067 192.168.2.100:5068
Basically EPICS_CA_ADDR_LIST a list of Host:EPICS_CA_SERVER_PORT. Again, type "echo $ EPICS_CA_ADDR_LIST " to make sure the settings of EPICS_CA_ADDR_LIST is really what you expect.
This nasty method works for nasty networking.
Cheers,
Yong
On 3/18/21, 6:34 PM, "Tech-talk on behalf of Manoussakis, Adamandios via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    Hi Lewis,
    Env Vars are
    Host setup
    EPICS_CA_ADDR_LIST=Client IP
    EPICS_CA_AUTO_ADDR=YES
    Client setup
    EPICS_CA_ADDR_LIST=Host IP
    I don't think the env variables are the cause in this case but I did try looking at the iptables --list and --list-rules after manually running Ralphs script with sudo and wasn't seeing the added rules from the script.  I would think its possible to manually sudo run the script to get them added but I am not that familiar with it.
    -----Original Message-----
    Sent: Thursday, March 18, 2021 3:02 PM
    To: Manoussakis, Adamandios <[email protected]>
    Cc: 'Ralph Lange' <[email protected]>; [email protected]
    On 03/18, Manoussakis, Adamandios via Tech-talk wrote:
    > Setup is as follows:
    > Client 192.168.1.50
    > Client running caget PV1
    > Env variable CA_ADDR is set to the host ip and CA_AUTO is set to YES
    > Host 192.168.2.100
    > Host running 4-5 IOCs (script is in both of the
    > /etc/network/if-up/down.d folders and have been made executable) Env
    > variable CA_ADDR is set to the client ip and CA_AUTO is set to YES
    Those aren't the right environment variables.  You might be abbreviating the names on purpose, but I would recommend you state the exact names you're using so that no one has to guess what you mean, and also just in case you've got a typo in any of them.
    Lewis
RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue J. Lewis Muir via Tech-talk
Prev: measComp R3-0 available Mark Rivers via Tech-talk
Next: Job Opening at SLAC National Accelerator Laboratory Zelazny, Michael Stanley via Tech-talk
Prev: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Next: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
