Subject: Re: Disable UI responsiveness Monitor in CSS-Phoebus
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Usmani, Imran Ali" <[email protected]>
Date: Mon, 22 Mar 2021 12:19:42 +0000
>If I disable UI Responsiveness Monitor by setting  ui_monitor_period=0 in file >core/ui/src/main/resources/phoebus_ui_preferences.properties
>while building css-phoebus, will it cause any trouble while using it?
Setting  ui_monitor_period=0 is exactly the way to disable the UI responsiveness monitor.
There are no downsides to doing that, except that if you do run into a UI freeze-up, you won't get a stack trace that might allow us to fix the underlying issue.
To set  ui_monitor_period=0, however, you should not edit the file core/ui/src/main/resources/phoebus_ui_preferences.properties and recompile.
Instead, set the preference value as described on https://control-system-studio.readthedocs.io/en/latest/preferences.html.
For example, put this into your local "my_settings.ini" file:
org.phoebus.ui/ui_monitor_period=0
and then start phoebus with "-settings /path/to/my_settings.ini"
> I am asking this because running css-phoebus on a remote system through SSH and X11 forwarding is affecting UI performance.
That is about the worst possible scenario ;-)
X-via-ssh used to be a very convenient way to run UI apps remotely, but it's also slow, and modern apps where a button is no longer just a flat rectangle but some rounded rect with shaded background etc., all those drawing commands tend to be slow via X/ssh. VNC or similar commercial tools like Thinlinc tend to offer much better performance.
Still, sometimes X-via-ssh is the only option you might have, and then setting the ui_monitor_period to zero makes sense.
Kay
Re: Disable UI responsiveness Monitor in CSS-Phoebus Usmani, Imran Ali via Tech-talk
Prev: Re: Libera BLM Support Anyone? Abdalla Ahmad via Tech-talk
Next: Make a Tango controlled device visible in EPICS Birke, Thomas via Tech-talk
Prev: Disable UI responsiveness Monitor in CSS-Phoebus Usmani, Imran Ali via Tech-talk
Next: Re: Disable UI responsiveness Monitor in CSS-Phoebus Usmani, Imran Ali via Tech-talk
