Subject: Disable UI responsiveness Monitor in CSS-Phoebus
From: "Usmani, Imran Ali via Tech-talk" <[email protected]>
Date: Mon, 22 Mar 2021 01:17:36 +0000
If I disable UI Responsiveness Monitor by setting  ui_monitor_period=0 in file core/ui/src/main/resources/phoebus_ui_preferences.properties
while building css-phoebus, will it cause any trouble while using it?
From looking at the documentation and code, I think it checks UI responsiveness by pinging UI and waiting for response.
If UI Freeze(response is late than ui_monitor_period ms) is detected, it reports it and dumps UI threads stack trace.
Since it just detects UI Freeze and logs stack trace, will disabling it in production cause any major issue or affect robustness?
I am asking this because running css-phoebus on a remote system through SSH and X11 forwarding is affecting UI performance.
If my network is slow(around 20 Mbps), the css-phoebus application freezes and later it makes my entire local system(where I have my SSH client) slow.
If I run a css-phoebus installation with UI Responsiveness Monitor disabled, this does not happen.
My local and remote system are both rhel7. Any other recommendation regarding this are welcome.
Imran
Re: Disable UI responsiveness Monitor in CSS-Phoebus Kasemir, Kay via Tech-talk
Prev: Re: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Next: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Prev: Re: vscode extension for EPICS Victor Nadot via Tech-talk
Next: Re: Disable UI responsiveness Monitor in CSS-Phoebus Kasemir, Kay via Tech-talk
