---------- Forwarded message --------- From: Jeong Han Lee <[email protected]> Date: Tue, Mar 23, 2021 at 10:56 Subject: Re: MRF kernel module, failed to map BARS To: GAGET Alexis <[email protected]> HI Alexis, You have to allow all other cards to be booted after your cpu is ready to communicate with each other through MCH pcie. The order is 1 MCH / 2 CPU / 3 Others You can contact ESS to ask about their configuration for MTCA or please check https://github.com/icshwi/mch_config HTH, Han On Tue, Mar 23, 2021 at 8:34 AM GAGET Alexis via Tech-talk <[email protected]> wrote: > > Dear All, > > Here at saclay we are using MRF timing system with MTCA.4 in R2 NAT crate. > > I’m using the COMex-E3 and a MCH-PHYS80. The IOC using the mrfioc2 driver is running on the Comex and the mrf kernel module is loaded on it. I have forked from ESS version of mrfioc2, and the kernel module I built seems the same. > > My kernel version is : 3.10.0-1160.15.2.el7.x86_64 on a CenTOS Linux 7.9.2009 > > It works globally very well, but I have a reproducible issue: > > When I reboot the whole R2 crate and when I load the MRF kernel module I have the following message : > > [ 347.344081] mrf: module verification failed: signature and/or required key missing - tainting kernel > [ 347.345504] mrf-pci 0000:04:00.0: Attaching MRF device w/o PLX bridge (00007011) > [ 347.345581] mrf-pci 0000:04:00.0: can't ioremap BAR 0: [??? 0x00000000 flags 0x0] > [ 347.345646] mrf-pci 0000:04:00.0: Failed to map BARS! 0 0 > [ 347.345918] mrf-pci 0000:06:00.0: Attaching MRF device w/o PLX bridge (00007011) > [ 347.345989] mrf-pci 0000:06:00.0: can't ioremap BAR 0: [??? 0x00000000 flags 0x0] > [ 347.346053] mrf-pci 0000:06:00.0: Failed to map BARS! 0 0 > > Consequence, my Comex can’t find some of my EVR or EVM (some are found..). > > To make it work I just have to reboot the Comex and after that it’s working. Meaning after a shutdown I have to reboot it twice… > > Does anyone have this kind of trouble ? Knows how to solve it ? or even understand this message ? > > Thanks for your consideration > > Alexis GAGET > > CEA Saclay - DRF/Irfu/DIS/LDISC > > Bâtiment 472 – pièce 105 > > [email protected] > > 01 69 08 95 17 > >
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
