1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Possible to Populate CSS text fields with JDBC calls?
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: "Kasemir, Kay" <[email protected]>
Date: Thu, 25 Mar 2021 00:49:24 +0000
Hey Kay,
I was wondering if it is possible to pull a value from a database using CSS’s JDBC implementation into say a text field on our CSS GUI.  I have been trying to figure out best way to store different configurations (Multiple experiment configurations) in a database then push them to all the IOC (PVs) when needed.  I was hoping there was an easy solution to doing this, but maybe I need to write a python script to grab and write to the CSS GUI text fields using jdbc?
DB -> CSS (using jdbc calls?) -> fill in CSS GUI fields -> which would write to the PVs
Adam
Re: Possible to Populate CSS text fields with JDBC calls? Kasemir, Kay via Tech-talk
Prev: Re: Cant compile makeBaseApp.pl directories with make Mark Rivers via Tech-talk
Next: RE: MRF kernel module, failed to map BARS GAGET Alexis via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Possible to Populate CSS text fields with JDBC calls? Kasemir, Kay via Tech-talk
