Hi Marco,
> /usr/bin/ld: cannot find -lreadline
> collect2: error: ld returned 1 exit status
> can anyone give me a hint on how to understand what is happening?
You need to do either one of these things:
- Install the readline development package on Debian. Perhaps called readline-devel or something similar.
- Edit /usr/local/epics/base/configure/os/CONFIG_SITE.Common.linux-x86_64 to use the EPICS readline version instead of the system package.
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>CONFIG_SITE.Common.linux-x86_64
Sent: Wednesday, March 24, 2021 7:52 AM
To: [email protected]
Subject: Cant compile makeBaseApp.pl directories with make
Hello, im kind of newbie into EPICS and im trying to understand how to create an IOC with the EPICS getting started tutorials. I created the $HOME/EPICS/TEST/testIoc directory on a debian 9 docker container and used the makeBaseApp.pl command to create the example app. however, when i use the make command, i get the following error:
/usr/local/epics/base/configure/RULES_BUILD:305: recipe for target 'libtestIocSupport.so' failed
make[3]: *** [libtestIocSupport.so] Error 1
make[3]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp/src/O.linux-x86_64'
/usr/local/epics/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp/src'
/usr/local/epics/base/configure/RULES_DIRS:83: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp'
/usr/local/epics/base/configure/RULES_DIRS:83: recipe for target 'testIocApp.install' failed
make: *** [testIocApp.install] Error 2
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Cant compile makeBaseApp.pl directories with make Marco A. Barra Montevechi Filho via Tech-talk
Re: Cant compile makeBaseApp.pl directories with make Siddons, David via Tech-talk
Possible to Populate CSS text fields with JDBC calls? Manoussakis, Adamandios via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
