Subject: Cant compile makeBaseApp.pl directories with make
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Wed, 24 Mar 2021 12:52:15 +0000
Hello, im kind of newbie into EPICS and im trying to understand how to create an IOC with the EPICS getting started tutorials. I created the $HOME/EPICS/TEST/testIoc directory on a debian 9 docker container and used the makeBaseApp.pl command to create the example app. however, when i use the make command, i get the following error:
/usr/bin/ld: cannot find -lreadline
collect2: error: ld returned 1 exit status
/usr/local/epics/base/configure/RULES_BUILD:305: recipe for target 'libtestIocSupport.so' failed
make[3]: *** [libtestIocSupport.so] Error 1
make[3]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp/src/O.linux-x86_64'
/usr/local/epics/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp/src'
/usr/local/epics/base/configure/RULES_DIRS:83: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp'
/usr/local/epics/base/configure/RULES_DIRS:83: recipe for target 'testIocApp.install' failed
make: *** [testIocApp.install] Error 2
can anyone give me a hint on how to understand what is happening?
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Cant compile makeBaseApp.pl directories with make Siddons, David via Tech-talk
Re: Cant compile makeBaseApp.pl directories with make Mark Rivers via Tech-talk
Prev: Re: Keithley 6487 support Pratt, Linda (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Cant compile makeBaseApp.pl directories with make Siddons, David via Tech-talk
Prev: Support for CAEN DT5730 / DT5730S? Mark Rivers via Tech-talk
