Hi Peter,
Thanks for the tip. I did have PvCam, PICam, and LightField installed, all from Photometrics/Princeton Instruments. I uninstalled all of them, but that did not help. I have the FLIR driver installed for my Firewire card, but it still
does not see the camera.
Hi Mark,
I have some experience with the Flea2 camera type.
I have a project that uses it a LabView - and not an EPICS - context.
One point of knowledge I can share is that the Windows device driver for Photometrics/Princeton cameras somehow breaks the device driver for the Flea2 camera, if
they are installed on the same PC.
I’ve no idea whether or not this would the case with Linux also.
I don’t know if this information is relevant or helpful at all.
Cheers,
Peter.
Hi Mirek,
Ø
Does it mean that the Flea2 would work with area-detector under Windows?
In principle yes. It should work on Linux too, I just don’t know if it has been tested.
I actually have a Flea2 camera (FL2-03S2M). I just plugged it into my Windows machine. The FLIR FlyCap2 viewer software is not finding the camera, but it should. I have sent a support request to FLIR to have them help me with that problem.
If they can figure it out I will see if ADPointGrey works with the camera on Windows. I don’t have a Linux machine with a Firewire card, so I can’t test that.
Sent: Monday, March 29, 2021 4:57 PM
To: Mark Rivers <[email protected]>
Cc: [email protected]
Subject: Re: Area Detector and Flea2 camera problem
Hi Mark and Han,
Thank you very much for your expertise and suggestions.
>This means that the vendor SDK is unable to find any Point Grey/FLIR cameras.
I will just give a last try. I will read the serial number and set it explicitly in EPICS db.
>The Flea2 is a Firewire camera. In principle that is supported by the FlyCap2 SDK that ADPointGrey uses. However, I am not sure if anyone has actually used a Point Grey Firewire camera with ADPointGrey on Linux, and almost certainly not on a Ubuntu 20.
>Is replacing the camera an option? New GigE or USB-3.0 cameras with much better performance than the Flea2 are less than $500.
Well, we just have this camera so we wanted to make use of it even if it is not so new.
Hi Mirek,
> Number of cameras detected: 0
> 2021/03/25 17:56:30.674 pointGrey:connectCamera: no cameras found
Firewire cameras are not supported by the new FLIR Spinnaker SDK, so upgrading to that is not an option.
From: Tech-talk <[email protected]> on behalf of Miroslaw Dach via Tech-talk <[email protected]>
Sent: Thursday, March 25, 2021 8:09 PM
To: [email protected]
Subject: Area Detector and Flea2 camera problem
Hello,
I am using the latest Area Detector R3-10 on Ubuntu 20.04 focal (x86-64).
Unfortunately the Flea2 camera which is connected to the computer is not detected:
Startup script:
epicsEnvSet("IOC","iocPointGrey")
epicsEnvSet("TOP","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC")
epicsEnvSet("ADPOINTGREY","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/../..")
epicsEnvSet("SUPPORT","/home/beamline/EPICS/synApps/support")
epicsEnvSet("ASYN","/home/beamline/EPICS/synApps/support/asyn-R4-41")
epicsEnvSet("AREA_DETECTOR","/home/beamline/EPICS/synApps/support/areaDetector-R3-10")
epicsEnvSet("ADSUPPORT","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADSupport")
epicsEnvSet("ADCORE","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADCore")
epicsEnvSet("AUTOSAVE","/home/beamline/EPICS/synApps/support/autosave-R5-10-2")
epicsEnvSet("BUSY","/home/beamline/EPICS/synApps/support/busy-R1-7-3")
epicsEnvSet("CALC","/home/beamline/EPICS/synApps/support/calc-R3-7-4")
epicsEnvSet("SNCSEQ","/home/beamline/EPICS/synApps/support/seq-2-2-8")
epicsEnvSet("SSCAN","/home/beamline/EPICS/synApps/support/sscan-R2-11-4")
epicsEnvSet("DEVIOCSTATS","/home/beamline/EPICS/synApps/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/home/beamline/EPICS/base-7.0.5")
errlogInit(20000)
dbLoadDatabase("/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/dbd/pointGreyApp.dbd")
# Prefix for all records
epicsEnvSet("PREFIX", "13PG1:")
# Use this line for the first Point Grey camera in the system
epicsEnvSet("CAMERA_ID", "0")
# Use this line for a specific camera by serial number, in this case a Flea2 Firewire camera
epicsEnvSet("CAMERA_ID", "9211601")
pointGreyConfig("PG1", 18402100, 0x1, 0)
2021/03/25 17:56:30.651 pointGrey:connectCamera: no cameras found
2021/03/25 17:56:30.651 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
2021/03/25 17:56:30.651 pointGrey:pointGrey: camera connection failed (3)
2021/03/25 17:56:30.674 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
2021/03/25 17:56:30.674 pointGrey::report error calling connectCamera()
Supported properties
./start_epics: line 1: 78175 Segmentation fault (core dumped) ../../bin/linux-x86_64/pointGreyApp st.cmd
kernel reports the following problem:
692673.933782] pointGreyApp[78175]: segfault at 0 ip 00007f56601b1a1f sp 00007ffecc98aa50 error 4 in libpointGrey.so[7f56601a4000+11000]
[692673.933794] Code: 84 9f 04 00 00 48 8b 85 30 e8 ff ff 49 8b b7 60 05 00 00 48 8b bd 38 e8 ff ff 49 8b 94 07 c8 05 00 00 4d 8b b4 07 58 06 00 00 <48> 8b 06 48 89 95 20 e8 ff ff ff 50 78 48 8b b5 38 e8 ff ff 4c 89
Does anybody have an idea what might be wrong?
Best Regards
Mirek
- Re: Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
- Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
- Re: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
- RE: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
- RE: Area Detector and Flea2 camera problem Heesterman, Peter J via Tech-talk
Re: Questions about arrays Mooney, Tim M. via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
