Subject: Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device
To: "Wlodek, Jakub" <[email protected]>
Date: Tue, 6 Apr 2021 13:51:05 +0000
Hi Jakub,
> I know there is external software I could use to create a virtual serial device from an ethernet connection, but is there a way to do this from within EPICS?
I don't know of a way to do that inside EPICS.
Moxa provides a "Real TTY" Linux driver that allows creating ports like /dev/ttyr00 to the Moxa device.  These provide all of the serial port controls (baud, parity, etc.).
https://www.moxa.com.cn/getmedia/6fbafa79-1113-4953-a6cc-bef28dae1180/moxa-real-tty-driver-for-nport-tech-note-v1.0.pdf
From: Tech-talk <[email protected]> on behalf of Wlodek, Jakub via Tech-talk <[email protected]>
Sent: Tuesday, April 6, 2021 8:34 AM
To: [email protected]
Subject: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device
Good morning EPICS community,
I had the following question regarding one of the devices that I am currently working on supporting. Essentially, I am using an asynPortDriver
based driver integrated with the device vendor SDK. The vendor SDK has a connection function that expects a string representing either identification
for the USB device to communicate over the USB bus (this I have working fine), or a TTY serial device for communicating over serial (ex. /dev/ttyS0, COM1 on Windows).
When connected directly to the serial port of the target machine, the device connects and this works OK.
However, ideally, we would prefer to use a MOXA ethernet-to-serial adapter to talk to the device, and I am not sure what the best approach for this is. Traditionally,
for say a StreamDevice IOC I would use drvAsynIPPortConfigure(), and then configure the MOXA to communicate via serial on the other end, but given that
the device needs a serial device to connect, I wasn't sure how to handle that. I know there is external software I could use to create a virtual serial device from
Jakub
Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Wlodek, Jakub via Tech-talk
Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Maren Purves via Tech-talk
Prev: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Wlodek, Jakub via Tech-talk
Next: Re: phoebus LED in boolean button Pierrick M Hanlet via Tech-talk
Next: Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Wlodek, Jakub via Tech-talk
