On Apr 6, 2021, at 10:44 AM, Kyle Hesse wrote:
> Try adding the path to your dbd file in your db file. The link below offers an example under section 6.2.
TBH I don't think that will help, it should be possible to load a DBD file by hand without such a reference in it; if you later save the edited DB file it will get a reference to the DBD file like that included automatically.
> I have downloaded the latest release of VisualDCT via the github link (https://github.com/epics-extensions/VisualDCT/releases) to edit database files via the interface. When i try to execute the .jar file, a browsing window shows up to let me select a .db or .dbd file but after i select it the window closes and nothing happens. If i try to execute the program via the command java -jar VisualDCT.jar dbdfile.dbd dbfile.db (the files are in the same directory of the terminal) it generates the following message:
> Loading VisualDCT v2.8.2...
> Directive to load DBD: 'mvc3Include.dbd'.
> Directive to load DB: 'mvc3_channel.db'.
> No DBD loaded! Exiting...
> I suspect its something with my java configurations but im not sure. Does anyone knows if i am doing something wrong? Thanks in advance.
> Obs: i am operating it in a ubuntu 20.04.2 LTS
The fact that you got the “Directive to load” messages indicates that you have almost certainly installed and configured it properly.
I think the problem is that you aren’t loading a fully expanded DBD file. VisualDCT doesn’t know where your EPICS Base installation is, so it can’t use the mvc3Include.dbd file that you’re giving it because that file mostly only contains a list of names of other DBD files that also need to be loaded. It needs the expanded version, which is probably called mvc3.dbd and should be found in your application’s dbd directory after you have run ‘make’ at least once to build it.
Please try that and let us know if it now works.
- Andrew
Complexity comes for free, simplicity you have to work for.
- Re: VisualDCT doesnt load .dbd or .db files Hugo Slepicka via Tech-talk
- VisualDCT doesnt load .dbd or .db files Marco A. Barra Montevechi Filho via Tech-talk
- Re: VisualDCT doesnt load .dbd or .db files Kyle Hesse via Tech-talk
RE: phoebus LED in boolean button Manoussakis, Adamandios via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
