Subject: Re: VisualDCT doesnt load .dbd or .db files
To: "[email protected]" <[email protected]>, "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Tue, 6 Apr 2021 15:44:50 +0000
Hello Marco,
Try adding the path to your dbd file in your db file. The link below offers an example under section 6.2.
https://epics-extensions.github.io/VisualDCT/doc/MAN-VisualDCT_Users_Manual.html#parser
Something like this:
#! DBDSTART
#! DBD("'mvc3Include.dbd")
#! DBDEND
Kyle
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Tuesday, April 6, 2021 10:30 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] VisualDCT doesnt load .dbd or .db files
Hello, EPICS community.
I have downloaded the latest release of VisualDCT via the github link (https://github.com/epics-extensions/VisualDCT/releases) to edit database files via the interface. When i try to execute the .jar file, a browsing window shows up to let me select a .db or .dbd file but after i select it the window closes and nothing happens. If i try to execute the program via the command java -jar VisualDCT.jar dbdfile.dbd dbfile.db (the files are in the same directory of the terminal) it generates the following message:
Loading VisualDCT v2.8.2...
Directive to load DBD: 'mvc3Include.dbd'.
Directive to load DB: 'mvc3_channel.db'.
No DBD loaded! Exiting...
I suspect its something  with my java configurations but im not sure. Does anyone knows if i am doing something wrong? Thanks in advance.
Obs: i am operating it in a ubuntu 20.04.2 LTS
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: VisualDCT doesnt load .dbd or .db files Johnson, Andrew N. via Tech-talk
VisualDCT doesnt load .dbd or .db files Marco A. Barra Montevechi Filho via Tech-talk
Prev: Re: compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64. Johnson, Andrew N. via Tech-talk
Next: RE: phoebus LED in boolean button Manoussakis, Adamandios via Tech-talk
Prev: VisualDCT doesnt load .dbd or .db files Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: VisualDCT doesnt load .dbd or .db files Johnson, Andrew N. via Tech-talk
