Subject: |
Re: compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64. |
"Johnson, Andrew N. via Tech-talk" <[email protected]> |
To: |
Noboru Yamamoto <[email protected]> |
Cc: |
EPICS tech-talk <[email protected]> |
Date: |
Tue, 6 Apr 2021 15:30:04 +0000 |
Hi Noboru,
On Apr 5, 2021, at 11:03 PM, Noboru Yamamoto wrote:
> Hi, friends in EPICS community.
> Recently I got Apple Macbook pro with Apple M1 CPU, running macOS Big Sur.
> Today, I successfully built fat binaries for EPICS R7 base software.
> So far I tested softIOC and ca_get command in both x86_64 and arm64 architectures using clang/clang++ compilers from Apple.
Thank-you for checking and confirming that fat binaries build and work properly, I don’t have access to an M1 CPU yet to do that myself (although this laptop will need replacing soon as it can’t be upgraded beyond macOS Catalina).
- Andrew
> To build these binraries, I just needed to modify Makefiles as shown below.
> 1) In base/configure/os/CONFIG_SITE.Common.darwin-x86, set the ARCH_CLASS variable as
> ARCH_CLASS = x86_64 arm64
> 2) Rebuild "libreadline.dylib" in /usr/local/lib ( or where you installed it) as a fat binary.
> To build it, I modified readline-8.1/Makefile:
> CFLAGS = -arch x86_64 -arch arm64 -g -O2 -Wno-parentheses -Wno-format-security
> and readline-8.1/shlib/Makefile:
> SHOBJ_LDFLAGS = -arch x86_64 -arch arm64 -dynamiclib -dynamic -undefined dynamic_lookup
> Regards,
> Noboru Yamamoto
> J-PARC accelerator control group
> KEK, JAPAN
Complexity comes for free, simplicity you have to work for.
- compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64. Noboru Yamamoto via Tech-talk
VisualDCT doesnt load .dbd or .db files Marco A. Barra Montevechi Filho via Tech-talk
Re: VisualDCT doesnt load .dbd or .db files Kyle Hesse via Tech-talk
<2021>
2025
2026
Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Wlodek, Jakub via Tech-talk
<2021>
2025
2026
