Subject: compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64.
From: Noboru Yamamoto via Tech-talk <[email protected]>
To: Till Straumann via Tech-talk <[email protected]>
Date: Tue, 6 Apr 2021 13:03:43 +0900
Hi, friends in EPICS community.
Recently I got Apple Macbook pro with Apple M1 CPU, running macOS Big Sur.
Today, I successfully built fat binaries for EPICS R7 base software.
So far I tested softIOC and ca_get command in both x86_64 and arm64 architectures
using clang/clang++ compilers from Apple.
To build these binraries, I just needed to modify Makefiles as shown below.
1) In base/configure/os/CONFIG_SITE.Common.darwin-x86, set the ARCH_CLASS variable as
	ARCH_CLASS = x86_64 arm64
2) Rebuild "libreadline.dylib" in /usr/local/lib ( or where you installed it) as a fat binary.
To build it,  I modified  readline-8.1/Makefile:
CFLAGS = -arch x86_64 -arch arm64 -g -O2 -Wno-parentheses -Wno-format-security
and readline-8.1/shlib/Makefile:
SHOBJ_LDFLAGS = -arch x86_64 -arch arm64 -dynamiclib -dynamic -undefined dynamic_lookup
Noboru Yamamoto
J-PARC accelerator control group
KEK, JAPAN
Noboru Yamamoto
Accelerator Control group
J-PARC center/KEK & JAEA
web: http://www-acc.kek.jp/EPICS_Gr/default.html
Re: compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64. Johnson, Andrew N. via Tech-talk
Prev: Re: Documentation to program CSS Phoebus scripts using JS and Python Johnson, Andrew N. via Tech-talk
Next: Re: Thermo Radiation Detectors FHT 6020 Smith, Martin via Tech-talk
Prev: Re: Thermo Radiation Detectors FHT 6020 Smith, Martin via Tech-talk
Next: Re: compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64. Johnson, Andrew N. via Tech-talk
