I think it would be nice if the error logging and debugging output in stream used asynTrace. My understanding is that asyn is currently the only I/O system supported by stream, so it is always present. However, should be possible to abstract the support so the diagnostics can either use asyn if it is available, or something else if it is not.
The advantages of asynTrace include:
- Fine-grained control what metadata is in the message prefix (timestamp, asyn port, source line #, thread name)
- Ability to turn on debugging messages for a specific asyn port and address. Currently when stream debugging is enabled all records with stream support print messages.
- Finer control over debugging messages (ASYN_TRACE_WARNING, ASYN_TRACEIO_DRIVER, ASYN_TRACE_INFO)
- Ability to route only the asynTrace output to a user-defined log file. This can be done to different files on a per-port basis.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Hu, Yong via Tech-talk
Sent: Sunday, April 11, 2021 6:34 PM
To: Ben Franksen <[email protected]>; EPICS tech-talk <[email protected]>; Zimoch Dirk (PSI) <[email protected]>
Subject: Re: streamdevice error messages
Hi Ben,
(a): if you are using the latest StreamDevice (2.8.19, or my fork as shown in #b), set the variable "streamDebugColored" to 0 either in st.cmd or the EPICS shell: var streamDebugColored 0 (streamDebugColored is default to 1)
(b): I have a fork from PSI StreamDevice: https://github.com/huyong1979/StreamDevice. You can try my fork. It works on Debian 7 (base-3.14.12.3 , gcc 4.7.2, make 3.81). I can turn off the timestamps added to messages by setting the variable "streamDebugTS" to 0 (streamDebugTS is default to 1).
Cheers,
Yong
On 4/9/21, 7:06 AM, "Tech-talk on behalf of Ben Franksen via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
Is there a way in streamdevice to
(a) turn off coloring of messages?
(b) turn off the timestamps added to messages?
Rationale: we log everything happening on an IOC's console and the color
escape codes make the logs hard to read. Also, the logging already
inserts a timestamp, so the extra timestamp added by streamdevice gets
in the way.
Cheers
Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned. -- Richard Feynman
- streamdevice error messages Ben Franksen via Tech-talk
- Re: streamdevice error messages Hu, Yong via Tech-talk
Vacancy at PSI: Software Scientists to develop data reduction and processing solutions Zimoch Dirk (PSI) via Tech-talk
Driver for Agilent TwisTorr 305-IC Gay, Gregory (DLSLtd, RAL, LSCI) via Tech-talk
<2021>
2025
2026
Re: streamdevice error messages Ben Franksen via Tech-talk
<2021>
2025
2026
