Subject: Creating a record and using its instance.
From: "Wang, Andrew via Tech-talk" <[email protected]>
Date: Mon, 12 Apr 2021 18:46:30 +0000
All,
This will be a lengthy post, so please bear with me.
I am currently trying to create my own record called “sample”, then create a record instance of “sample” for use in an IOC. The manual helped immensely, but I am still a bit stuck and would appreciate some insight.
For creating the record, what I did first was first create a support application by using the command:
makeBaseApp.pl -t support sample
Then, I modified the configure/RELEASE file so that the correct path for EPICS is specified. Next, I went to sampleApp/src and created two files: sampleRecord.dbd and sampleRecord.c. Here is what I currently have for them.
sampleRecord.dbd:
recordtype(sample)
      include "dbCommon.dbd"
      field(VAL, DBF_DOUBLE)
            asl(ASL0)
            pp(TRUE)
      field(OVAL, DBF_DOUBLE)
sampleRecord.c:
// EPICS IOC header files
#include "callback.h"
#include "dbAccess.h"
#include "dbBase.h"
#include "dbDefs.h"
#include "dbFldTypes.h"
#include "dbScan.h"
#include "dbStaticLib.h"
#include "devLib.h"
#include "devSup.h"
#include "drvSup.h"
#include "epicsExport.h"
#include "initHooks.h"
#include "link.h"
#include "recSup.h"
#include "special.h"
#include "taskwd.h"
// Record support header files
#include "sampleRecord.h"
// C standard library header files
#include <stdio.h>
static long init_record(void*, int);
static long process(void*);
rset sampleRSET={
    RSETNUMBER,
    NULL,
    NULL,
    init_record,
    process,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL
epicsExportAddress(rset, sampleRSET);
static long init_record(void* precord, int pass)
      //long status;
      //int size_desc;
      sampleRecord *r;
      r = (sampleRecord *) precord;
      if (!pass)
            //size_desc = sizeof(r->desc) / sizeof(char);
            //snprintf(r->desc, size_desc, "%s", "Hello");
            printf("I've been initialized!\n");
            return 0;
      return 0;
static long process(void* precord)
      printf("I've been processed!\n");
      return 0;
My goal is to use channel access and see those two messages printed when running iocBoot. For instance, when I run caput sample_record_instance.PROC 1, hopefully it will print “I’ve been processed”.
In my following steps, I modified the Makefile in sampleApp/src to be:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# build a support library
LIBRARY_IOC += sample
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += sampleRecord.h
# install sample.dbd into <top>/dbd
DBD += sampleRecord.dbd
# specify all source files to be compiled and added to the library
sample_SRCS += sampleRecord.c
sample_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
So after making these modifications and additions, I ran make in TOP and no errors were produced.
Finally, I created an IOC application and iocBoot type called “test_sample”. In the configure/RELEASE file, I included:
SAMPLE = ${HOME}/myepics/support/sample
Then, I created a record instance for “sample” in a database file within test_sampleApp/Db:
record(sample, “sample_record_instance”)
      field(DESC, “Yay”)
Finally, I modified the Makefile in test_sampleApp/src to be:
TOP=../..
# Build the IOC application
PROD_IOC = test_sample
# test_sample.dbd will be created and installed
DBD += test_sample.dbd
# test_sample.dbd will be made up from these files:
test_sample_DBD += base.dbd
# Include dbd files from all support applications:
test_sample_DBD += sampleRecord.dbd
# Add all the support libraries needed by this IOC
test_sample_LIBS += sample
# test_sample_registerRecordDeviceDriver.cpp derives from test_sample.dbd
test_sample_SRCS += test_sample_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
test_sample_SRCS_DEFAULT += test_sampleMain.cpp
test_sample_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#test_sample_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Finally link to the EPICS Base libraries
test_sample_LIBS += $(EPICS_BASE_IOC_LIBS)
However, when I run make in TOP, I receive the following error:
test_sample_registerRecordDeviceDriver.o: In function `_GLOBAL__sub_I_test_sample_registerRecordDeviceDriver':
test_sample_registerRecordDeviceDriver.cpp:(.text.startup+0x2b5): undefined reference to `pvar_func_sampleRecordSizeOffset'
Any thoughts?
Thank you,
Andy
Re: Creating a record and using its instance. Hu, Yong via Tech-talk
Re: Creating a record and using its instance. Johnson, Andrew N. via Tech-talk
Prev: Re: streamdevice error messages Ben Franksen via Tech-talk
Next: Re: line scan camera with ADAravis driver skips frames Katie Matusik via Tech-talk
Prev: Driver for Agilent TwisTorr 305-IC Gay, Gregory (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Creating a record and using its instance. Hu, Yong via Tech-talk
