Firstly, this will make your build pass. Replace this line
#include "sampleRecord.h"
with these lines:
#define GEN_SIZE_OFFSET
#undef GEN_SIZE_OFFSET
#include "epicsExport.h"
Now, let’s back to the other business.
1) It seems you are new to EPICS. Why do you want to create a customized record type? Just for learning purpose? I did this kind of thing when I was a graduate student, but never did it again after I started
my real career job. Hope your purpose is not for a real production application.
2) I think the built-in record types should be enough for 99% (if not 100%) EPICS applications. If your application is really unique, you could describe your requirements, your purpose, etc. so that other
people here can help you find a reasonably practical solution.
Cheers,
Yong
All,
This will be a lengthy post, so please bear with me.
I am currently trying to create my own record called “sample”, then create a record instance of “sample” for use in an IOC. The manual helped immensely, but I am still a bit stuck and would appreciate some insight.
For creating the record, what I did first was first create a support application by using the command:
makeBaseApp.pl -t support sample
Then, I modified the configure/RELEASE file so that the correct path for EPICS is specified. Next, I went to sampleApp/src and created two files: sampleRecord.dbd and sampleRecord.c. Here is what I currently have for them.
sampleRecord.dbd:
recordtype(sample)
include "dbCommon.dbd"
field(VAL, DBF_DOUBLE)
asl(ASL0)
pp(TRUE)
field(OVAL, DBF_DOUBLE)
sampleRecord.c:
// EPICS IOC header files
#include "callback.h"
#include "dbAccess.h"
#include "dbBase.h"
#include "dbDefs.h"
#include "dbFldTypes.h"
#include "dbScan.h"
#include "dbStaticLib.h"
#include "devLib.h"
#include "devSup.h"
#include "drvSup.h"
#include "initHooks.h"
#include "link.h"
#include "recSup.h"
#include "special.h"
#include "taskwd.h"
// Record support header files
// C standard library header files
#include <stdio.h>
static long init_record(void*, int);
static long process(void*);
rset sampleRSET={
RSETNUMBER,
NULL,
NULL,
init_record,
process,
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
NULL,
NULL
epicsExportAddress(rset, sampleRSET);
static long init_record(void* precord, int pass)
//long status;
//int size_desc;
sampleRecord *r;
r = (sampleRecord *) precord;
if (!pass)
//size_desc = sizeof(r->desc) / sizeof(char);
//snprintf(r->desc, size_desc, "%s", "Hello");
printf("I've been initialized!\n");
return 0;
return 0;
static long process(void* precord)
printf("I've been processed!\n");
return 0;
My goal is to use channel access and see those two messages printed when running iocBoot. For instance, when I run caput sample_record_instance.PROC 1, hopefully it will print “I’ve been processed”.
In my following steps, I modified the Makefile in sampleApp/src to be:
TOP=../..
include $(TOP)/configure/CONFIG
# ADD MACRO DEFINITIONS AFTER THIS LINE
# build a support library
LIBRARY_IOC += sample
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += sampleRecord.h
# install sample.dbd into <top>/dbd
DBD += sampleRecord.dbd
# specify all source files to be compiled and added to the library
sample_SRCS += sampleRecord.c
sample_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
So after making these modifications and additions, I ran make in TOP and no errors were produced.
Finally, I created an IOC application and iocBoot type called “test_sample”. In the configure/RELEASE file, I included:
SAMPLE = ${HOME}/myepics/support/sample
Then, I created a record instance for “sample” in a database file within test_sampleApp/Db:
record(sample, “sample_record_instance”)
field(DESC, “Yay”)
Finally, I modified the Makefile in test_sampleApp/src to be:
TOP=../..
# Build the IOC application
PROD_IOC = test_sample
# test_sample.dbd will be created and installed
DBD += test_sample.dbd
# test_sample.dbd will be made up from these files:
test_sample_DBD += base.dbd
# Include dbd files from all support applications:
test_sample_DBD += sampleRecord.dbd
# Add all the support libraries needed by this IOC
test_sample_LIBS += sample
# test_sample_registerRecordDeviceDriver.cpp derives from test_sample.dbd
test_sample_SRCS += test_sample_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
test_sample_SRCS_DEFAULT += test_sampleMain.cpp
test_sample_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#test_sample_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Finally link to the EPICS Base libraries
test_sample_LIBS += $(EPICS_BASE_IOC_LIBS)
However, when I run make in TOP, I receive the following error:
test_sample_registerRecordDeviceDriver.o: In function `_GLOBAL__sub_I_test_sample_registerRecordDeviceDriver':
test_sample_registerRecordDeviceDriver.cpp:(.text.startup+0x2b5): undefined reference to `pvar_func_sampleRecordSizeOffset'
Any thoughts?
Thank you,
Andy
