> On Apr 12, 2021, at 6:54 PM, Wang, Andrew via Tech-talk <[email protected]> wrote:
> I guess the reason why I am doing this is mostly due to curiosity. Also, my team is a bit curious to know what the process for creating records are. As this demonstrates, it is quite challenging.
Hi Andy--
Creating record instances using existing record types is quite easy. With the existing record types from EPICS base, plus a handful of other record types in widespread use, most if not all of your needs should be covered. That is one of the real strengths of EPICS: without having to write any code, it’s possible to setup and configure your control system runtime logic using EPICS records.
Nonetheless, it looks like it was a good learning experience for you and welcome to the community.
Steven Hartman
[email protected]
- Creating a record and using its instance. Wang, Andrew via Tech-talk
- Re: Creating a record and using its instance. Johnson, Andrew N. via Tech-talk
- RE: Creating a record and using its instance. Wang, Andrew via Tech-talk
Moving to phoebus alarm server Gotz, Malte via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
