Subject: Array widget in Display Builder
From: Tomasz Brys via Tech-talk <[email protected]>
Date: Wed, 14 Apr 2021 12:27:14 +0000
I need help to understand an Array widget.
I created an array widget with five TextEntries. I set PV as loc://myarray<VDoubleArray>. When I try to write something to the Array I got an error.
When I set PV as loc://myarray<VDoubleArray>(0) the value 0 appears in my Array and I can write whatever I want. Even if I write more elements than five.
But e.g if I write [1,2,3,4,5] it is OK, then I write[11,22,33] I will see [11,22,33,4,5]. It looks like the array widget ignore the size of array which I want to write.
Is it a bug or special feature? If this is a feature how I can remove remaining [4,5]. Can anyone explain? Maybe I am using the widget wrong?
Cheers
Tomasz Brys
Re: Array widget in Display Builder Kasemir, Kay via Tech-talk
Prev: Re: External: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Next: CSS Display builder web runtime. Vishnu Patel via Tech-talk
Prev: Re: problems with running EPICS Gateway on virtual machines? Ben Franksen via Tech-talk
Next: Re: Array widget in Display Builder Kasemir, Kay via Tech-talk
