> java.net.MalformedURLException: no protocol: /var/lib/tomcat9/webapps/dbwr/LCPC/ColdBox.bob
Looks like you tried to access
https://your.server/dbwr/view.jsp?display=/var/lib/tomcat9/webapps/dbwr/LCPC/ColdBox.bob
The display link needs to be a valid URL, for example this to access a file on the server:
https://your.server/dbwr/view.jsp?display=file://var/lib/tomcat9/webapps/dbwr/LCPC/ColdBox.bob
But you might want to block generic file access for security reasons on either the tomcat level and/or by defining WHITELIST* settings.
So better serve the display files from your web as well and then use
https://your.server/dbwr/view.jsp?display=http://your.server/displays/LCPC/ColdBox.bob
Search the web for setting up Apache httpd and tomcat so that httpd is used for serving plain files (like .../displays) and redirecting dedicated URLs to tomcat (like dbwr/*).
-Kay
From: Tech-talk <[email protected]> on behalf of Vishnu Patel via Tech-talk <[email protected]>
Sent: Wednesday, April 14, 2021 9:07 AM
To: EPICS tech-talk <[email protected]>
Subject: [EXTERNAL] CSS Display builder web runtime.
Hello,
I am using display builder web runtime with tomcat9 and java 14.
The below error has been encountered.
HTTP Status 500 – Internal Server Error
Type Exception Report
Message Servlet execution threw an exception
Description The server encountered an unexpected condition that prevented it from fulfilling the request.
Exception
javax.servlet.ServletException: Servlet execution threw an exception
org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
Root Cause
java.lang.Error: Cannot create display /var/lib/tomcat9/webapps/dbwr/LCPC/ColdBox.bob {}
dbwr.servlets.ScreenServlet.createHtml(ScreenServlet.java:60)
dbwr.servlets.DisplayCache.lambda$getOrCreate$0(DisplayCache.java:32)
java.base/java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1708)
dbwr.servlets.DisplayCache.getOrCreate(DisplayCache.java:32)
dbwr.servlets.ScreenServlet.doGet(ScreenServlet.java:109)
javax.servlet.http.HttpServlet.service(HttpServlet.java:634)
javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
Root Cause
java.base/java.net.URL.<init>(URL.java:672)
java.base/java.net.URL.<init>(URL.java:568)
java.base/java.net.URL.<init>(URL.java:515)
dbwr.parser.Resolver.<init>(Resolver.java:65)
dbwr.servlets.ScreenServlet.createHtml(ScreenServlet.java:48)
Thanks
Vishnu
- CSS Display builder web runtime. Vishnu Patel via Tech-talk
Re: Array widget in Display Builder Kasemir, Kay via Tech-talk
<2021>
2025
2026
EPICS-Support for Amtek / Gamry potentiostat Sintschuk, Michael via Tech-talk
<2021>
2025
2026
