Subject: Re: Array widget in Display Builder
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Tomasz Brys <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 14 Apr 2021 14:08:33 +0000
>So, If I want to have an EMPTY array of size 30 what I have to do?
>I do not want to change the size of this array. What I want is to write sometimes 3 elements, and sometimes empty it (keeping size of 30).
>Maybe I should use a Table widget instead?
We might mix our nomenclature when it comes to size/length/capacity.
For the array widget, they're all the same and fixed.
"Size 30" means there are always 30 elements.
'EMPTY' would mean no elements, size=length=0, while capacity may still be 30.
The array widget doesn't support that. You could set the array to [ 0, 0, 0, 0, ..., 0 ] with 30 x [0], but not EMPTY as in [].
Yes, for a display, you could use a table widget, but that requires a (small) script to transform the array data from the PV into the rows/columns of the table.
-Kay
Array widget in Display Builder Tomasz Brys via Tech-talk
Re: Array widget in Display Builder Kasemir, Kay via Tech-talk
Re: Array widget in Display Builder Tomasz Brys via Tech-talk
Prev: Re: Array widget in Display Builder Tomasz Brys via Tech-talk
Next: Re: problems with running EPICS Gateway on virtual machines? Ben Franksen via Tech-talk
Next: CSS Display builder web runtime. Vishnu Patel via Tech-talk
