Thanks Matt, I think I might go that route with pyepics.
Sent from my iPhone
I did have one more question with regards to the execute command in the action button. That technically is just calling a cmd line argument that I place there correct ( python example.py )? Is there any way to trigger this based off a rule
or is it only running the execute command when the button is clicked ?
Thanks for your help
Hi:
Yes, jython is still different from CPython, so Numpy and the like which call out to native C or even fortran code cannot be used from jython.
> might have to go the pythonIoc route
That's definitely a better
idea. Scripts in the display, if used at all, should be limited to simple task, certainly not for number crunching based on numpy/pandas. That's better moved into a service (IOC, pcaspy, ..).
Hi Kay,
Thanks for the link, I tried adding to my settings.ini file but still doesn’t seem to be finding the packages I am importing in my script (pandas, numpy).
org.csstudio.display.builder.runtime/python_path=C:\Users\PC\AppData\Local\Programs\Python\Python39\
I did find a fairly old post by you on tech talk and was wondering if this still applied to Phoebus/Jython (seems like jython still doesn’t work with numpy from looking around)
“CSS BOY scripts are executed in jython, not python.
Most of the default python modules are also available in jython, but when you install python modules with binary dependencies like numpy, MySQL_python, .. those are not available in jython.”
If this is the case, it seems like I might have to go the pythonIoc route but I really just wanted to have the script get called when a pv changed value (was using the button to write a value change causing the script to trigger).
Adam
- Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
- Re: Python Script call from Button press, module not found Kasemir, Kay via Tech-talk
- RE: Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
- Re: Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
Re: Python Script call from Button press, module not found Michael Davidsaver via Tech-talk
<2021>
2025
2026
Re: [EXTERNAL] Python Script call from Button press, module not found Hartman, Steven via Tech-talk
<2021>
2025
2026
