Subject: Fanout and asub interaction issues
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Sat, 17 Apr 2021 02:29:21 +0000
All,
I am encountering an interesting problem and would again appreciate your insights.
Essentially, I have a fanout record and asub record that resemble the following pseudocode:
record(fanout, “fanout_rec”)
              field(SCAN, “Passive”)
              field(LNK0, “aao_rec_1”)
              field(LNK1, “aao_rec_2”)
              field(LNK2, “asub_rec”)
record(asub, “asub_rec”)
              field(SNAM, “c_code”)
              field(INPA, “aao_rec_1”)
              field(FTVA, “CHAR”)
              field(NOA, 2048)
              field(INPB, “aao_rec_2”)
              field(FTVB, “DOUBLE”)
              field(NOB, 2048)
My goal was to first process the first two aao records so they contain the most up-to-date values before processing “asub_rec”. When I attempt to retrieve the values from both aao records within “c_code”, it is getting previous values that they contained prior to their latest processing.
For instance, if “aao_rec_1” contained “hello”, then when I print out “(CHAR*)prec->a” in “c_code”, it prints out nothing. But when I process it again, but with a different value, I print out “hello”, rather than the latest value it has.
I’m beginning to think it might be better to use the PP flag for INPA and INPB like this:
              field(INPA, “aao_rec_1 PP”)
              field(FTVA, “CHAR”)
              field(NOA, 2048)
              field(INPB, “aao_rec_2 PP”)
              field(NOB, 2048)
Any thoughts or suggestions?
Andy
Re: Fanout and asub interaction issues Mooney, Tim M. via Tech-talk
Prev: Two versions of asyn are complied into an IOC application Hu, Yong via Tech-talk
Next: Re: Fanout and asub interaction issues Mooney, Tim M. via Tech-talk
