Subject: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ...
Date: Tue, 20 Apr 2021 20:43:48 +0000
Hello everyone,
I am trying to build the latest asyn (commit a2da087) against base-R7.0.4.1, but encountered the same error “No rule to make target 'ipSNCServer.o'” as reported on tech-talk:
https://epics.anl.gov/tech-talk/2007/msg01045.php
However, I do have SNCSEQ defined in asyn/configure/RELEASE:
SNCSEQ=/usr/lib/epics
EPICS_BASE=/usr/lib/epics
As you see, both EPICS_BASE and SNCSEQ point to the same path in my RELEASE. This is the historical tradition at NSLS-2: we install all EPICS stuff (base, support modules) in a flat directory “/usr/lib/epics”.
$ ls /usr/lib/epics/
bin  cfg  configure  db  dbd  include  lib  startup  templates
This has been working well for base-3.14.12, meaning I can build the latest asyn (commit a2da087) against base-3.14.12 with SNCSEQ=/usr/lib/epics. Now, this kind of directory structure seems to not work for base-R7.0.4.1. I do see some warnings when building asyn against base-R7.0.4.1:
/usr/lib/epics/configure/RULES_BUILD:575: Warning: Base configure/RULES_BUILD file included more than once. Does configure/RELEASE have multiple pointers to /usr/lib/epics?
If I make a change like this: SNCSEQ=/home/yhu/epics/seq-2-2-6 where I have built “seq” in my home directory, I can build the latest asyn (commit a2da087) against base-R7.0.4.1 successfully.
So, the problem seems related to “Does configure/RELEASE have multiple pointers to …”. A simple search on Google/Tech-Talk does not give me any hints to fix the problem. Any suggestions are welcomed!
Yong
Re: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Hu, Yong via Tech-talk
Prev: Re: How to use asyGenericPointerSyncIO interface? Mark Rivers via Tech-talk
Next: Re: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Hu, Yong via Tech-talk
