Hi all,
Both the Andor Ikon and Teledyne Shadobox detectors I use have defective pixel maps that need to be corrected. Currently these maps are specified in a text file listing bad pixels, rows or columns. They would typically be corrected with an appropriate median filter.
I was thinking about implementing the correction as a plugin. Has anyone done that already?
Thanks, David
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
- Re: AreaDetector Defective Pixel Correction Plugin Mark Rivers via Tech-talk
Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Tynan Ford via Tech-talk
Device driver for Delta Elektronika SM15-400 [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
<2021>
2025
2026
Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Josh Fiddler via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
