Subject: |
Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) |
Josh Fiddler via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 22 Apr 2021 17:46:41 -0400 |
Ok. I'll dig into that in the morning. Thank you all for your prompt responses. Much appreciated.
Hi Josh,
On Apr 22, 2021, at 4:06 PM, Josh Fiddler via Tech-talk <[email protected]> wrote:
> I managed to compile EPICS 7.0.5 within the MDSplus Alapine container and ran `make runtests`. Only two tests Failed
> ###### Begin Error Output ######
> /Test Summary Report
> epicsTimeZoneTest.t (Wstat: 256 Tests: 160 Failed: 4)
> Failed tests: 84, 90, 104, 110
> Non-zero exit status: 1
> epicsThreadTest.t (Wstat: 256 Tests: 15 Failed: 2)
> Failed tests: 3, 5
> Files=48, Tests=4285, 211 wallclock secs ( 0.49 usr 0.07 sys + 1.42 cusr 0.72 csys = 2.70 CPU)
> Result: FAIL
> ###### End Error Output ######
> Are the test cases published?
The code for those two test programs can be found in the modules/libcom/test directory. You can run the compiled test programs by hand, they generate human-readable output in a standard format called TAP (Test Anything Protocol) which is supported by Perl’s test harness. To run them:
> woz$ cd modules/libcom/test/O.linux-x86_64
> woz$ ./epicsTimeZoneTest
> 1..160
> # POSIX 1445259616
> # TZ = "EST5EDT"
> # test_localtime(1445259616, ...)
> ok 1 - epicsTime_localtime() success
> ok 2 - sec 16==16
> ok 3 - min 0==0
> ok 4 - hour 9==9
> ok 5 - mday 19==19
> ok 6 - mon 9==9
> ok 7 - year 2015==2015
> ok 8 - wday 1==1
> ok 9 - yday 291==291
> ok 10 - isdst 1==1
> # test_gmtime(1445259616, ...)
> # POSIX 1421244931
> # TZ = "EST5EDT"
> # test_localtime(1421244931, ...)
> ok 81 - epicsTime_localtime() success
> ok 82 - sec 31==31
> ok 83 - min 15==15
> ok 84 - hour 9==9
> ok 85 - mday 14==14
> ok 86 - mon 0==0
> ok 87 - year 2015==2015
> ok 88 - wday 3==3
> ok 89 - yday 13==13
> ok 90 - isdst 0==0
> # TZ = "CST6CDT"
> ok 101 - epicsTime_localtime() success
> ok 102 - sec 31==31
> ok 103 - min 15==15
> ok 104 - hour 8==8
> ok 105 - mday 14==14
> ok 106 - mon 0==0
> ok 107 - year 2015==2015
> ok 108 - wday 3==3
> ok 109 - yday 13==13
> ok 110 - isdst 0==0
> ok 157 - year 2015==2015
> ok 158 - wday 3==3
> ok 159 - yday 13==13
> ok 160 - isdst 0==0
> Results
> Tests: 160
> Passed: 160 = 100.00%
> woz$ ./epicsThreadTest
> 1..15
> # System has 4 CPUs
> ok 1 - ncpus > 0
> # main() thread 0x7fc39bd001e0
> ok 2 - Join delayed parent (2.00108 seconds)
> ok 3 - Join tests #1 completed
> ok 4 - Join delayed parent (2.00075 seconds)
> ok 5 - Join tests #2 completed
> ok 6 - pget == pset
> ok 7 - thread.getPriority() == epicsThreadGetPriority(self)
> ok 8 - pget == pset
> ok 9 - thread.getPriority() == epicsThreadGetPriority(self)
> ok 10 - pget == pset
> ok 11 - thread.getPriority() == epicsThreadGetPriority(self)
> ok 12 - threadB epicsThreadIsOkToBlock() = 1
> ok 13 - threadA epicsThreadIsOkToBlock() = 0
> ok 14 - infoB.didSomething
> ok 15 - infoA.didSomething
> Results
> Tests: 15
> Passed: 15 = 100.00%
From the test failures you reported it looks like the musl C library that comes with Alpine Linux may have problems with its DST calculations (tests 84, 90, 104 and 110 in the first program) for the year 2015 at least, and its pthread_join() routine might not be working (tests 3 and 5 in the second program). The first issue you can probably ignore, but the pthread_join() might be more of a problem and is something that you should check since the IOC code does now use it.
- Andrew
Complexity comes for free, simplicity you have to work for.
- EPICS in Docker image Build Error base-3.15.6 (alpine linux) Josh Fiddler via Tech-talk
- Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Johnson, Andrew N. via Tech-talk
- Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Josh Fiddler via Tech-talk
pvdata structure not writing to other pvs Pierrick M Hanlet via Tech-talk
<2021>
2025
2026
AreaDetector Defective Pixel Correction Plugin David Vine via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
