Subject: Re: RPM packages for EPICS
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Hu, Yong" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 21 Apr 2021 15:35:51 +0000
Hi Yong,
On Apr 21, 2021, at 9:43 AM, Hu, Yong <[email protected]> wrote:
> Has any facility built, smoothly deployed and happily used RPM packages for EPICS installation of the base and popular support modules (seq, asyn, motor, streamDevice, etc.)? Please share your repositories (or building rules / specs) and your experience. Thank you!
ITER has been building RPMs for all their software including EPICS modules on RHEL for many years, but I don’t believe they are allowed to share the results with the community for intellectual property reasons (administrative and legal, not for any technical reasons).
Despite running RHEL the APS will never use RPMs because we need the ability to install multiple versions of our support modules simultaneously, without knowing very far in advance which combinations of modules we might need. The EPICS build system was designed with that model in mind, and the Sumo tool from HZB (BESSY) makes it very easy to manage and build EPICS support modules using that model. For the APS Upgrade project we are using a combination of Conda packages for user applications and Sumo for EPICS IOC code.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: RPM packages for EPICS Ralph Lange via Tech-talk
RPM packages for EPICS Hu, Yong via Tech-talk
Prev: Re: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Hu, Yong via Tech-talk
Next: RE: AreaDetector Defective Pixel Correction Plugin Mark Rivers via Tech-talk
Prev: RPM packages for EPICS Hu, Yong via Tech-talk
Next: Re: RPM packages for EPICS Ralph Lange via Tech-talk
