Subject: Re: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ...
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 21 Apr 2021 14:56:33 +0000
Thank you, Mark! It works with empty values. I do not see asyn is trying to build “testIPServerApp” any more.
SUPPORT=
IPAC=
SNCSEQ=
On 4/21/21, 10:35 AM, "Mark Rivers" <[email protected]> wrote:
Hi Yong,
  • So, my questions: do we really need the following 3 lines in asyn/configure/RELEASE?
  • SUPPORT=/corvette/home/epics/devel
  • IPAC=$(SUPPORT)/ipac-2-15
  • SNCSEQ=$(SUPPORT)/seq-2-2-5
Actually asyn configure/RELEASE has explanatory comments before each of those lines:
#  IPAC is only necessary if support for Greensprings IP488 is required
#  IPAC release V2-7 or later is required.
# SEQ is required for testIPServer
## For sCalcout support in asynOctet - applications include asynCalc.dbd
#CALC=$(SUPPORT)/calc-3-7-3
# If CALC was built with SSCAN support then SSCAN must be defined for testEpicsApp
#SSCAN=$(SUPPORT)/sscan-2-11-3
#  EPICS_BASE 3.14.6 or later is required
EPICS_BASE=/corvette/usr/local/epics-devel/base-7.0.4
I believe you can achieve what you want without editing RELEASE by putting these lines in RELEASE.local
SUPPORT=
IPAC=
SNCSEQ=
I think that should work because RELEASE.local is read after RELEASE, and so you will replace those 3 definitions.  I have not tested it, so please try it.
asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Hu, Yong via Tech-talk
Re: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Hu, Yong via Tech-talk
RE: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Mark Rivers via Tech-talk
Prev: RPM packages for EPICS Hu, Yong via Tech-talk
Next: Re: RPM packages for EPICS Johnson, Andrew N. via Tech-talk
Prev: RE: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Mark Rivers via Tech-talk
Next: Re: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Johnson, Andrew N. via Tech-talk
