Yest, that's right. Permissions to write PVs. But logging out & in, or
using 'sudo' are not acceptable solutions for this situation. Any
solution has to come from the Phoebus graphical interface. No command
line. The computer session has to remain untouched.
Best,
Óscar
El 21/04/2021 a las 21:49, Kasemir, Kay escribió:
We are going to have several users using Phoebus. Different users have
different permissions to view and to edit, like any other system.
the change has to be made without logging out from the current computer session.
Permissions to do _what_?
Write PVs?
That's handled by Channel Access (or PV Access) security, which is based on the current user.
Phoebus (or EDM, MEDM, python CA library, command line caput, ...) don't have any way to change that user.
The only option you have is either log out & log back in,
or use 'sudo' to change user and start another instance of the program as that different user.
-Kay
- Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Johnson, Andrew N. via Tech-talk
- What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
- Re: What is the best (and simple) way to implement security in a Phoebus solution? J. Lewis Muir via Tech-talk
- Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
- Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Kasemir, Kay via Tech-talk
Re: State Machines SNL or SEQ records? Manoussakis, Adamandios via Tech-talk
Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
