Hi Kay,
I have re-read my message and I think that I know why we are not
understanding each other.
When I say "low-privileged account" (or a high one), I don't mean an OS
user account. What I mean is a different worker profile using Phoebus.
Maybe an example could help:
Imagine that you have a computer account named "john". John is an
account with some privileges. It does not matter which ones. Using that
account, a scientist is running Phoebus. As a scientist, he may view and
change a few things. Not many. However, when that scientists finishes
his task, he gets up and he leaves its seat available for an engineer.
The enginner can view and modify the same PVs that the scientist,
however, he also may view and change other things. So, he changes his
current Phoebus profile from scientist to engineer. His screen changes
and now he is capable of changing many things.
Take into account that the computer session has not changed. No "sudos".
No command line. The computer account is still the same, "john". Nothing
has changed. The different worker profiles exist inside Phoebus.
Best,
Óscar
El 21/04/2021 a las 21:49, Kasemir, Kay escribió:
We are going to have several users using Phoebus. Different users have
different permissions to view and to edit, like any other system.
the change has to be made without logging out from the current computer session.
Permissions to do _what_?
Write PVs?
That's handled by Channel Access (or PV Access) security, which is based on the current user.
Phoebus (or EDM, MEDM, python CA library, command line caput, ...) don't have any way to change that user.
The only option you have is either log out & log back in,
or use 'sudo' to change user and start another instance of the program as that different user.
-Kay
- What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
- Re: What is the best (and simple) way to implement security in a Phoebus solution? J. Lewis Muir via Tech-talk
- Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
- Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Johnson, Andrew N. via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
