On 4/22/21 2:06 PM, Josh Fiddler via Tech-talk wrote:
> Thank you for having me!
> I managed to compile EPICS 7.0.5 within the MDSplus Alapine container and ran `make runtests`. Only two tests Failed
> ###### Begin Error Output ######
> /Test Summary Report
> epicsTimeZoneTest.t (Wstat: 256 Tests: 160 Failed: 4)
> Failed tests: 84, 90, 104, 110
> Non-zero exit status: 1
> epicsThreadTest.t (Wstat: 256 Tests: 15 Failed: 2)
> Failed tests: 3, 5
> Files=48, Tests=4285, 211 wallclock secs ( 0.49 usr 0.07 sys + 1.42 cusr 0.72 csys = 2.70 CPU)
> Result: FAIL
> ###### End Error Output ######
> Are the test cases published?
The individual test results should have been printed just before the summary.
You can also run:
> $ make tapfiles
Which will produce a number of .tap files with the test output.
> $ find . -name epicsTimeZoneTest.tap
And to summarize them all a different way
> $ make test-results
> On Tue, Apr 20, 2021 at 7:33 PM Johnson, Andrew N. <[email protected] <mailto:[email protected]>> wrote:
> Hi Josh,
> Welcome to the EPICS community!
> On Apr 20, 2021, at 6:07 PM, Josh Fiddler via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
> > I have what seems to be a unique problem.
> Apparently, but it should be easily solvable...
> > To build the MDSplus EPICS interface requirements I appear to need the MDSplus libraries. MDSplus provides a docker image based on Alpine linux. I've added the required build tools with `apk`.
> I don’t know of anyone using Alpine Linux with EPICS yet, but we're a pretty big community now.
> > Everything goes swimmingly, so far as I can tell, until it comes to `src/libCom/osi` and then the compiler complains and quits. Here's the error
> > ############# Begin Error snippet #############
> > usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd
> -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -c ../../../src/libCom/env/envSubr.c
> > ../../../src/libCom/env/envSubr.c: In function 'envGetInetPortConfigParam':
> > ../../../src/libCom/env/envSubr.c:411:21: error: 'IPPORT_USERRESERVED' undeclared (first use in this function)
> > if (epicsParam<=IPPORT_USERRESERVED || epicsParam>USHRT_MAX) {
> > ../../../src/libCom/env/envSubr.c:411:21: note: each undeclared identifier is reported only once for each function it appears in
> > make[3]: *** [../../../configure/RULES_BUILD:232: envSubr.o] Error 1
> > make[3]: Leaving directory '/epics/base-3.15.6/src/libCom/O.linux-x86_64'
> > make[2]: *** [../../configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
> > make[2]: Leaving directory '/epics/base-3.15.6/src/libCom'
> > make[1]: *** [../configure/RULES_DIRS:84: libCom.install] Error 2
> > make[1]: Leaving directory '/epics/base-3.15.6/src'
> > ############# END ERROR SNIPPET #############
> > The Asks:
> > 1) Is there anyone who has some insights into this error or has built in Alpine?
> The macro IPPORT_USERRESERVED is defined in /usr/include/netinet/in.h in my Linux (RHEL-7) system so my guess is that you need some networking -devel or similar package to be installed that provides that header or an equivalent. It’s definitely a standard networking constant so you just have to work out how to get hold of the right headers.
> Our build documentation is somewhat out of date. If you want to test your build after it’s done, run ‘make runtests’ and it will execute the built-in test programs and report the results – always a good thing to do after building on a new OS-type.
> Good luck!
> - Andrew
> Complexity comes for free, simplicity you have to work for.
- EPICS in Docker image Build Error base-3.15.6 (alpine linux) Josh Fiddler via Tech-talk
- Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Johnson, Andrew N. via Tech-talk
- Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Josh Fiddler via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
