Thanks Michael,
That was it. The PVA_ADDR_LIST to include the port, the wrong port. I
missed that
part when I was looking earlier.
Thanks again,
Pierrick
On 4/23/21 5:42 PM, Michael Davidsaver wrote:
> On 4/23/21 2:48 PM, Pierrick M Hanlet via Tech-talk wrote:
>> Hi Andrew,
>> I get:
>> epics> dbpvar PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs 4
>> PVA links in record named 'PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs'
>> P:S12OFP conn=F 0 disconnects, 0 type changes,
>> provider 'pva'
>> 0/1 channels connected used by 1 links
> "conn=F" is the key point. The link isn't connecting to the target PV "P:S12OFP".
> Does a "pvget P:S12OFP" from the IOC host succeed? To understand why we need to
> look at the PVA client settings used by the IOC ($EPICS_PVA_*).
> Also, it would be good if status==LINK_ALARM were getting set in this situation, but it isn't.
> Probably because I'm not processing initially disconnected links. Something to look into...
>>>> Warning: "Channel write request failed"
> Are you loading any Access Security configuration?
> Can we see the init script or softIocPVA arguments used?
>> Cheers,
>> Pierrick
>> On 4/23/21 4:31 PM, Johnson, Andrew N. wrote:
>>> Hi Pierrick,
>>> Does the iocsh ‘dbpvar’ command tell you anything interesting/useful about the state of the pva link? You can give it a record name, or “*”, and an integer level for more and more detail about the link(s).
>>> - Andrew
>>> On Apr 23, 2021, at 4:10 PM, Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
>>>> Hi all,
>>>> I'm running v7.0.3.1 on an SL7.8 machine. I'm using structured data, with a sub-structure
>>>> called Control. I know that the structure/sub-structure is being properly set by testing it
>>>> with a pvmonitor:
>>>> pvmonitor -r Control P:S12OFP
>>>> which yields:
>>>> P:S12OFP structure
>>>> structure Control
>>>> time_t timeStamp <undefined>
>>>> long secondsPastEpoch 0
>>>> int nanoseconds 0
>>>> int userTag 0
>>>> short value 8
>>>> I want this Control value to populate another record which has the form:
>>>> record(longin,"PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs") {
>>>> field(DESC,"Trigger Control PVs from acnet device")
>>>> field(SCAN,"Passive")
>>>> field(INP,{pva:{pv:"P:S12OFP",
>>>> field:"Control.value",
>>>> proc:"CP"}})
>>>> field(FLNK,"PIP2IT-HPRF-SSR1-SSA2-00:OFP:SetPVs.PROC")
>>>> However, this value doesn't change despite its input value changing. Furthermore,
>>>> if I attempt to change it's value with:
>>>> caput PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs
>>>> then get the error:
>>>> Old : PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs 0
>>>> CA.Client.Exception...............................................
>>>> Context: "op=1, channel=PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs, type=DBR_STRING, count=1, ctx="PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs""
>>>> Source File: ../oldChannelNotify.cpp line 160
>>>> New : PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs 0
>>>> Current Time: Fri Apr 23 2021 15:45:03.687389769
>>>> Thank you,
>>>> Pierrick
>>>> Pierrick Hanlet
>>>> Fermi National Accelerator
>>>> Accelerator Front End Controls
>>>> +1-630-840-5555 -- lab
>>>> +1-312-687-4980 -- mobile
>>>> "Whether you think you can or think you can't, you're right" -- Henry Ford
Pierrick Hanlet
- pvdata structure not writing to other pvs Pierrick M Hanlet via Tech-talk
- Re: pvdata structure not writing to other pvs Johnson, Andrew N. via Tech-talk
- Re: pvdata structure not writing to other pvs Pierrick M Hanlet via Tech-talk
- Re: pvdata structure not writing to other pvs Michael Davidsaver via Tech-talk
Modbus TCP and NEG power vacuum pump controller Baily, Scott A via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
