Subject: Re: how to install alh on raspberry pi 4
From: Huyn Woo Ryu via Tech-talk <[email protected]>
Date: Wed, 28 Apr 2021 09:22:09 +0900
On Wed, Apr 28, 2021 at 9:19 AM Huyn Woo Ryu <[email protected]> wrote:
Hi, Mark
Thank you for your reply
Before this error occurred, I had the below error.
make -C O.linux-arm -f ../Makefile TOP=../../.. \
    T_A=linux-arm install
make[1]: Entering directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm'
make[1]: *** No rule to make target '../../../lib/linux-arm/libX11.a', needed by 'alh'.  Stop.
make[1]: Leaving directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm'
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2
So I confirmed the location of libX11.a and  copied this file( /usr/lib/arm-linux-gnueabihf/libX11.a ) to  /home/pi/epics/base-3.15.8/lib/linux-arm/.
pi@raspberrypi:~/epics/extensions/src/alh1_2_35 $ locate libX11.a
    Ryu
On Tue, Apr 27, 2021 at 8:42 PM Mark Rivers <[email protected]> wrote:
Hi Ryu,
I have not worked with linux-arm, so I may be off base.
Error messages like this:
/usr/bin/ld: /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a(CrGlCur.o): undefined reference to symbol 'dlopen@@GLIBC_2.4'
often mean that the version of gcc (which supplies GLBIC) is older than the version required by a library you are using.
 Where did you get this file?   /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a
That seems like an unusual location for the X11 library file.
From: Tech-talk <[email protected]> on behalf of Huyn Woo Ryu via Tech-talk <[email protected]>
Sent: Tuesday, April 27, 2021 4:51 AM
To: [email protected]
Subject: how to install alh on raspberry pi 4
 Hi,I installed base-3.15.8 successfully on raspberry piBut when I install 'alh1_2_35' on raspberry pi OS(kernel version 5.10) on raspberry pi 4, it can't make successfully, the err as follows:
/usr/bin/ld: //lib/arm-linux-gnueabihf/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [../../../../base/configure/RULES_BUILD:204: alh] Error 1
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2   I don't know how to fix it, could you give me some advice on it?Please, Help me! I consumed many time for this problem.Ryu
how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
Re: how to install alh on raspberry pi 4 Mark Rivers via Tech-talk
Re: how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
Prev: Re: how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
Next: Re: how to install alh on raspberry pi 4 Mark Rivers via Tech-talk
