Subject: Re: how to install alh on raspberry pi 4
To: Huyn Woo Ryu <[email protected]>
Date: Wed, 28 Apr 2021 12:48:30 +0000
Hi Ryu,
Ø   there in no CONFIG_SITE.linux-arm.linux-arm as you see like below list
Then you will need to add one.  You can use CONFIG_SITE.linux-x86_64.linux-x86_64 as your model.
Ø  2. and below the list is the output of the command you requested.
Ø  pi@raspberrypi:~/epics/extensions/src $ ldd /usr/lib/arm-linux-gnueabihf/libX11.so
linux-vdso.so.1 (0xbe968000)
That looks fine.  When you build it will link with that .so file, and not the .a file.
Ø  3. there is no header file of libX11 library  to set  X11_INC variable .
There is no include file is not called libX11.h.  There should be an entire directory with X11 include files.  This is what I find on my Centos 7 system.
corvette:~/devel/dante>ls /usr/include/X11
CallbackI.h   Core.h       HookObjI.h    IntrinsicP.h  RectObjP.h    ShellI.h      VarargsI.h    XWDFile.h  Xcursor       Xlib.h      Xos.h        Xregion.h    Xwindows.h    extensions
Composite.h   CoreP.h      ICE           Object.h      ResConfigP.h  ShellP.h      Vendor.h      Xalloca.h  Xdefs.h       XlibConf.h  Xos_r.h      Xresource.h  Xwinsock.h    fonts
CompositeP.h  CreateI.h    ImUtil.h      ObjectP.h     ResourceI.h   StringDefs.h  VendorP.h     Xarch.h    Xft           Xlibint.h   Xosdefs.h    Xthreads.h   ap_keysym.h   keysym.h
ConstrainP.h  DECkeysym.h  InitialI.h    PM            SM            Sunkeysym.h   X.h           Xatom.h    Xfuncproto.h  Xlocale.h   Xpoll.h      Xtos.h       bitmaps       keysymdef.h
Constraint.h  EventI.h     Intrinsic.h   PassivGraI.h  SelectionI.h  ThreadsI.h    XF86keysym.h  Xauth.h    Xfuncs.h      Xmd.h       Xproto.h     Xutil.h      cursorfont.h
ConvertI.h    HPkeysym.h   IntrinsicI.h  RectObj.h     Shell.h       TranslateI.h  XKBlib.h      Xcms.h     Xlib-xcb.h    Xmu         Xprotostr.h  Xw32defs.h   dri
You need to find the equivalent directory on your system and define X11_INC to point to it.
Sent: Wednesday, April 28, 2021 2:20 AM
To: Mark Rivers
Cc: [email protected]
1. there in no CONFIG_SITE.linux-arm.linux-arm as you see like below list
pi@raspberrypi:~/epics/extensions/configure $ ls os/
CONFIG.linux-x86.linux-386                         CONFIG_SITE.linux-x86.linux-athlon
CONFIG_SITE.aix-ppc.aix-ppc                        CONFIG_SITE.linux-x86.linux-x86
CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu                CONFIG_SITE.osf-alpha.osf-alpha
CONFIG_SITE.Common.Common                          CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
CONFIG_SITE.cygwin-x86.cygwin-x86                  CONFIG_SITE.solaris-sparc64.solaris-sparc64
CONFIG_SITE.darwin-ppc.darwin-ppc                  CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
CONFIG_SITE.darwin-ppcx86.darwin-ppcx86            CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
CONFIG_SITE.darwin-x86.darwin-x86                  CONFIG_SITE.solaris-sparc.solaris-sparc
CONFIG_SITE.freebsd-x86_64.freebsd-x86_64          CONFIG_SITE.solaris-sparc.solaris-sparc64
CONFIG_SITE.freebsd-x86.freebsd-x86                CONFIG_SITE.solaris-x86_64.solaris-x86_64
CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu        CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
CONFIG_SITE.hpux-parisc.hpux-parisc                CONFIG_SITE.solaris-x86.solaris-x86
CONFIG_SITE.interix-x86.interix-x86                CONFIG_SITE.solaris-x86.solaris-x86_64
CONFIG_SITE.linux-ppc.linux-ppc                    CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin
CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug  CONFIG_SITE.win32-x86-debug.win32-x86-debug
CONFIG_SITE.linux-x86_64.linux-x86_64              CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
CONFIG_SITE.linux-x86-debug.linux-x86-debug        CONFIG_SITE.win32-x86.win32-x86
/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0xb6df2000)
libxcb.so.1 => /lib/arm-linux-gnueabihf/libxcb.so.1 (0xb6dad000)
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb6d9a000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6c4c000)
/lib/ld-linux-armhf.so.3 (0xb6f29000)
libXau.so.6 => /lib/arm-linux-gnueabihf/libXau.so.6 (0xb6c39000)
libXdmcp.so.6 => /lib/arm-linux-gnueabihf/libXdmcp.so.6 (0xb6c24000)
libbsd.so.0 => /lib/arm-linux-gnueabihf/libbsd.so.0 (0xb6bfc000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xb6be5000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6bbb000)
pi@raspberrypi:~/epics/extensions/src $ locate libX11
/usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1
/usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1.0.0
/usr/lib/arm-linux-gnueabihf/libX11.a
/usr/lib/arm-linux-gnueabihf/libX11.so.6
/usr/lib/arm-linux-gnueabihf/libX11.so.6.3.0
On Wed, Apr 28, 2021 at 10:31 AM Mark Rivers <[email protected]> wrote:
> So I confirmed the location of libX11.a and  copied this file( /usr/lib/arm-linux-gnueabihf/libX11.a ) to  /home/pi/epics/base-3.15.8/lib/linux-arm/.
That is definitely not the right way to do it.
In epics/extensions/configure/os you need to edit the correct CONFIG_SITE.* file to define the location of X11. For example CONFIG_SITE.linux-x86_64.linux-x86_64 on my system contains these lines:
X11_LIB=/usr/lib64
X11_INC=/usr/include
# OpenMotif location
MOTIF_LIB=/usr/lib64
MOTIF_INC=/usr/include
You need to define the X11_LIB and X11_INC directories for your system.
But I am not sure that will fix your problem.  Do you only have the static library /usr/lib/arm-linux-gnueabihf/libX11.a, or do you also have the dynamic library libX11.so?  If you do have the libX11.so file, then please send the output of this command:
ldd libX11.so
Sent: Tuesday, April 27, 2021 7:19 PM
To: Mark Rivers
Hi, Mark
Thank you for your reply
Before this error occurred, I had the below error.
make -C O.linux-arm -f ../Makefile TOP=../../.. \
    T_A=linux-arm install
make[1]: Entering directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm'
make[1]: *** No rule to make target '../../../lib/linux-arm/libX11.a', needed by 'alh'.  Stop.
make[1]: Leaving directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm'
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2
pi@raspberrypi:~/epics/extensions/src/alh1_2_35 $ locate libX11.a
On Tue, Apr 27, 2021 at 8:42 PM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Ryu,
I have not worked with linux-arm, so I may be off base.
Error messages like this:
/usr/bin/ld: /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a(CrGlCur.o): undefined reference to symbol 'dlopen@@GLIBC_2.4'
often mean that the version of gcc (which supplies GLBIC) is older than the version required by a library you are using.
 Where did you get this file?   /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a
That seems like an unusual location for the X11 library file.
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Huyn Woo Ryu via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Tuesday, April 27, 2021 4:51 AM
To: [email protected]<mailto:[email protected]>
Subject: how to install alh on raspberry pi 4
 Hi,I installed base-3.15.8 successfully on raspberry piBut when I install 'alh1_2_35' on raspberry pi OS(kernel version 5.10) on raspberry pi 4, it can't make successfully, the err as follows:
/usr/bin/ld: //lib/arm-linux-gnueabihf/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [../../../../base/configure/RULES_BUILD:204: alh] Error 1
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2   I don't know how to fix it, could you give me some advice on it?Please, Help me! I consumed many time for this problem.Ryu
Re: how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
Re: how to install alh on raspberry pi 4 Mark Rivers via Tech-talk
Prev: Re: how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
Next: Re: Pointing an IOC to system-level lib files for build Katie Matusik via Tech-talk
Next: Re: how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
