Subject: Recommendations for StreamDevice "architecture" flow
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 5 May 2021 16:37:49 +0000
All,
I would like to get an opinion from you all about whether these “architectures” are appropriate for StreamDevice. I’ve been looking at some posts on Tech-Talk about the general use for StreamDevice, specifically when there are multiple commands. Suppose I need to implement EPICS drivers for an instrument that has two commands: cmd1, cmd2, and cmd3. Here are some “architectures” I’ve tried and used:
  1. “Processing chain” method
record(ao, “cmd_1_set”)
              field(SCAN, “Passive”)
              field(DTYP, “stream”)
              field(OUT, “@instrument.proto setCmd1 $(PORT)”)
              field(FLNK, “cmd_1_get”)
record(ao, “cmd_2_set”)
              field(OUT, “@instrument.proto setCmd2 $(PORT)”)
              field(FLNK, “cmd_2_get”)
record(ao, “cmd_3_set”)
              field(OUT, “@instrument.proto setCmd3 $(PORT)”)
              field(FLNK, “cmd_3_get”)
record(ai, “cmd_1_get”)
              field(SCAN, “1 second”)
              field(INP, “@instrument.proto getCmd1 $(PORT)”)
record(ai, “cmd_2_get”)
              field(INP, “@instrument.proto getCmd2 $(PORT)”)
record(ai, “cmd_3_get”)
              field(INP, “@instrument.proto getCmd3 $(PORT)”)
  1. Fanout method
record(fanout, “slow_scan”)
              field(LNK0, “cmd_1_get”)
              field(LNK1, “cmd_2_get”)
              field(LNK2, “cmd_3_get”)
  1. Record scan method
Are all valid or is there one that is better than the other. Or is there an even better one that I haven’t thought of…
Andy
Re: Recommendations for StreamDevice "architecture" flow Ralph Lange via Tech-talk
RE: Recommendations for StreamDevice "architecture" flow Pearson, Matthew R. via Tech-talk
Prev: Re: Where is the image data in PV ArrayData of areaDetector Plugin NDPluginStdArrays? Mark Rivers via Tech-talk
Next: Re: Recommendations for StreamDevice "architecture" flow Ralph Lange via Tech-talk
Prev: Re: Support for Stanford PTC10 Kevin Peterson via Tech-talk
