Subject: calcout record processing
From: Randall Cayford via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 6 May 2021 10:43:50 -0700
I’m trying to do a simple chain of an input record, a calc record and an output record.  I can’t get the calc record to process unless I force it.
I have:
record(ai, “$(P):fsControl")
    field(DTYP, "asynInt32")
    field(PREC, "5")
    field(SCAN, "Passive")
    field(FLNK, "$(P):fsCalc PP")
record(calcout, "$(P):fsCalc")
    field(DESC, "Convert 1,0 shutter to 3,1")
    field(INPA, "$(P):fsControl")
    field(CALC, "A * 2 + 1")
    field(OUT,  "$(P):fsSet PP")
    field(OOPT, "Every Time")
record(ao, "$(P):fsSet")
    field(OUT,  "@asyn($(PORT,recursive),0,1)PMAC_WI_M8192")
If I put to fsControl, it sets but nothing happens.  If I put to fsCalc.PROC, everything works correctly - it reads fsControl, calculates the VAL and triggers fsSet with the calculated value.  If I make fsCalc SCAN periodic it also works.  I thought calc records were supposed to be processed whenever their inputs were processed.  I’ve tried with and without the FLNK in fsControl.  So I’m missing something about how calc record processing is triggered.
Randall Cayford
BCSB - LBNL
RE: calcout record processing Mark Rivers via Tech-talk
Re: calcout record processing Arnold, Ned D. via Tech-talk
Prev: RE: EPICS 7 base on WSL2 Leblanc, Gregory via Tech-talk
Next: RE: calcout record processing Mark Rivers via Tech-talk
Prev: Job Opportunity at APS/APS-U- Software Engineer Shen, Guobao via Tech-talk
