Subject: RE: calcout record processing
To: "'Arnold, Ned D.'" <[email protected]>, Randall Cayford <[email protected]>
Date: Thu, 6 May 2021 17:52:21 +0000
Ø  So you have two choices ...
Ø      FLNK from fsControl to fsCalc.
Ø          or
Ø      Change fsCalc.INPA to. "$(P):fsControl CP"
He did FLNK from fsControl to fsCalc.  If that FLNK is not actually processing fsCalc than I think it may be because of the DTYP/INP mismatch.
From: Tech-talk <[email protected]> On Behalf Of Arnold, Ned D. via Tech-talk
Sent: Thursday, May 6, 2021 12:49 PM
To: [email protected]; Randall Cayford <[email protected]>
Subject: Re: calcout record processing
>  I thought calc records were supposed to be processed whenever their inputs were processed.
Only of the CP flag is set for that input link.
        or
  Ned
From: Tech-talk <[email protected]> on behalf of Randall Cayford via Tech-talk <[email protected]>
Sent: Thursday, May 6, 2021 12:43 PM
To: [email protected] <[email protected]>
Subject: calcout record processing
I’m trying to do a simple chain of an input record, a calc record and an output record.  I can’t get the calc record to process unless I force it.
I have:
record(ai, “$(P):fsControl")
    field(DTYP, "asynInt32")
    field(PREC, "5")
    field(SCAN, "Passive")
    field(FLNK, "$(P):fsCalc PP")
record(calcout, "$(P):fsCalc")
    field(DESC, "Convert 1,0 shutter to 3,1")
    field(INPA, "$(P):fsControl")
    field(CALC, "A * 2 + 1")
    field(OUT,  "$(P):fsSet PP")
    field(OOPT, "Every Time")
record(ao, "$(P):fsSet")
    field(OUT,  "@asyn($(PORT,recursive),0,1)PMAC_WI_M8192")
If I put to fsControl, it sets but nothing happens.  If I put to fsCalc.PROC, everything works correctly - it reads fsControl, calculates the VAL and triggers fsSet with the calculated value.  If I make fsCalc SCAN periodic it also works.  I thought calc records were supposed to be processed whenever their inputs were processed.  I’ve tried with and without the FLNK in fsControl.  So I’m missing something about how calc record processing is triggered.
Randall Cayford
BCSB - LBNL
Re: [EXTERNAL] calcout record processing Hartman, Steven via Tech-talk
calcout record processing Randall Cayford via Tech-talk
Re: calcout record processing Arnold, Ned D. via Tech-talk
Prev: Re: calcout record processing Arnold, Ned D. via Tech-talk
Next: Re: [EXTERNAL] calcout record processing Hartman, Steven via Tech-talk
