On 5/7/21 6:15 AM, Mark Rivers via Tech-talk wrote:
> Hi Will,
> Unless you are sure that your application will need the GraphicsMagick file writer or the ADURL driver I would suggest just changing areaDetector/configure/CONFIG_SITE.local from
> WITH_GRAPHICSMAGICK = YES
> to
> WITH_GRAPHICSMAGICK = NO
> It looks like GraphickMagick needs some changes to work with gcc 10.2.0.
Yes, this is definitely a bug with GraphickMagick. (I've seen and caused
similar issues) In this case it seems to be specific to Windows (wrapped
by ifdef _VISUALC_). It also does not seem to have been reported, and is
still present it the latest revision.
https://github.com/ImageMagick/ImageMagick/blob/456ed029ee28fd979cab3473df866a73fa92f826/Magick%2B%2B/lib/Magick%2B%2B/Drawable.h#L73
https://github.com/ImageMagick/ImageMagick/blob/2747ccfc1044fc3da6d32ff1ebbca5e926fcf602/Magick%2B%2B/lib/Magick%2B%2B/Include.h#L74
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Smith, William via Tech-talk <[email protected]>
> Sent: Friday, May 7, 2021 7:35 AM
> To: [email protected]
> Subject: Building areaDetector on Windows with MSYS2 and MINGW64
> Hi,
> I am trying to build areaDetector on a Windows 10 machine to eventually use a support module from Diamond for an SES Electron Analyser. I followed the instructions here which I found excellent: https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/installation-windows-msys2.html
> I installed EPICS 3.15.7 and built asyn, busy, calc, seq, sscan and autosave against it. I then tried to install areaDetector and get the error below. I am using MSYS2 with MINGW64 which installs gcc version 10.2.0.
> I am not sure how to attempt to solve this problem, any help would be appreciated.
> Thanks
> Will
> make[6]: *** [/usr/local/epics/base/configure/RULES_BUILD:239: Image.obj] Error 1
> In file included from ../Magick++/Options.h:21,
> from ../ImageRef.cpp:15:
> ../Magick++/Drawable.h:96:8: error: explicit instantiation of 'class std::allocator<Magick::Coordinate>' in namespace 'Magick' (which does not enclose namespace 'std') [-fpermissive]
> 96 | std::allocator<Magick::Coordinate>;
> ../Magick++/Drawable.h:190:8: error: explicit instantiation of 'class std::allocator<Magick::Drawable>' in namespace 'Magick' (which does not enclose namespace 'std') [-fpermissive]
> 190 | std::allocator<Magick::Drawable>;
> ../Magick++/Drawable.h:270:6: error: explicit instantiation of 'class std::allocator<Magick::VPath>' in namespace 'Magick' (which does not enclose namespace 'std') [-fpermissive]
> 270 | std::allocator<Magick::VPath>;
> ../Magick++/Drawable.h:2239:6: error: explicit instantiation of 'class std::allocator<Magick::PathArcArgs>' in namespace 'Magick' (which does not enclose namespace 'std') [-fpermissive]
> 2239 | std::allocator<Magick::PathArcArgs>;
> ../Magick++/Drawable.h:2413:6: error: explicit instantiation of 'class std::allocator<Magick::PathCurvetoArgs>' in namespace 'Magick' (which does not enclose namespace 'std') [-fpermissive]
> 2413 | std::allocator<Magick::PathCurvetoArgs>;
> ../Magick++/Drawable.h:2597:6: error: explicit instantiation of 'class std::allocator<Magick::PathQuadraticCurvetoArgs>' in namespace 'Magick' (which does not enclose namespace 'std') [-fpermissive]
> 2597 | std::allocator<Magick::PathQuadraticCurvetoArgs>;
> make[6]: *** [/usr/local/epics/base/configure/RULES_BUILD:239: ImageRef.obj] Error 1
> make[6]: Leaving directory '/home/sissy_user/support/areaDetector/ADSupport/supportApp/GraphicsMagickSrc/Magick++/lib/O.windows-x64-mingw'
> make[5]: *** [/usr/local/epics/base/configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
> make[5]: Leaving directory '/home/sissy_user/support/areaDetector/ADSupport/supportApp/GraphicsMagickSrc/Magick++/lib'
> make[4]: *** [/usr/local/epics/base/configure/RULES_DIRS:84: lib.install] Error 2
> make[4]: Leaving directory '/home/sissy_user/support/areaDetector/ADSupport/supportApp/GraphicsMagickSrc/Magick++'
> make[3]: *** [/usr/local/epics/base/configure/RULES_DIRS:84: Magick++.install] Error 2
> make[3]: Leaving directory '/home/sissy_user/support/areaDetector/ADSupport/supportApp/GraphicsMagickSrc'
> make[2]: *** [/usr/local/epics/base/configure/RULES_DIRS:84: GraphicsMagickSrc.install] Error 2
> make[2]: Leaving directory '/home/sissy_user/support/areaDetector/ADSupport/supportApp'
> make[1]: *** [/usr/local/epics/base/configure/RULES_DIRS:84: supportApp.install] Error 2
> make[1]: Leaving directory '/home/sissy_user/support/areaDetector/ADSupport'
> make: *** [/usr/local/epics/base/configure/RULES_DIRS:84: /home/sissy_user/support/areaDetector/ADSupport.install] Error 2
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> 14109 Berlin
> Deutschland
- Building areaDetector on Windows with MSYS2 and MINGW64 Smith, William via Tech-talk
- Re: Building areaDetector on Windows with MSYS2 and MINGW64 Mark Rivers via Tech-talk
PVXS release 0.1.5 Michael Davidsaver via Tech-talk
<2021>
2025
2026
Running edm screens on RHEL8 Ivashkevych, Oksana via Tech-talk
<2021>
2025
2026
