Subject: RE: asynSetTrace
To: 'Petra Schwalbach' <[email protected]>
Date: Tue, 11 May 2021 13:32:24 +0000
Hi Petra,
Ø  epics> 2021/05/11 09:38:32.320 L0 -1 autoConnect could not connect: Can't connect to 10.32.192.132:2101: Connection timed out
There is no error message when those asynSetTrace commands were executed.
Then it must be another thing.
I cannot clarify the one-time message: "autoConnect could not connect ..." I ignored that.
Because drvAsynIPPortConfigure("L0","10.32.192.132:2101",0,0,0) does not cause an error and with netstat I can see that the IOC is connected with the hardware and I get an answer when I do caget melba_020:wf:on_get.
But when the hardware is not properly connected to the IOC, then it is obviously, that asynSetTrace doesn't work.
drvAsynIPPortConfigure will not give an error message even if the device is not reachable.  Because you have set the noAutoConnect flag to 0, which is normal, asyn will periodically try to connect to the device in case it become reachable.
The asynSetTrace commands will not give an error because the asyn port does indeed exist, even if it is not yet connected to the device.
The “autoConnect could not connect” message is the key.  It means the asyn IP port driver could not open a socket to the device.
You will get an answer when you do caget on the waveform record.  But does it actually contain the response you expect?
Here are things to try:
After iocInit type this command:
asynReport 1 L0
That will show if asyn thinks it is connected to the device.
If it is not connected then stop the IOC and in a Linux shell type this command:
telnet 10.32.192.132 2101
Does that connect to the device, or does it fail?  If it fails then the device is indeed not reachable.  Perhaps there is a firewall blocking it, or something else.
Sent: Tuesday, May 11, 2021 8:17 AM
Subject: Re: asynSetTrace
Hi Mark and Ralph
this is the output:
 ./startioc
#!../../bin/linux-x86_64/fug
< envPaths
epicsEnvSet("IOC","iocfug")
epicsEnvSet("TOP","/home/epics/fug")
epicsEnvSet("EPICS_SYNAPPS","/home/epics/synApps_6_1")
epicsEnvSet("ASYN","/home/epics/synApps_6_1/support/asyn-R4-36")
epicsEnvSet("CALC","/home/epics/synApps_6_1/support/calc-R3-7-3")
epicsEnvSet("STREAM","/home/epics/synApps_6_1/support/StreamDevice-2-8-9")
epicsEnvSet("AUTOSAVE","/home/epics/synApps_6_1/support/autosave-R5-10")
epicsEnvSet("BUSY","/home/epics/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("IOCSTATS","/home/epics/synApps_6_1/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/home/epics/base-7.0.3.1")
epicsEnvSet("STREAM_PROTOCOL_PATH", ".:../../db")
#epicsEnvSet("STREAM_PROTOCOL_PATH", "$(TOP)/db")
epicsEnvSet "P" "melba_020:"
epicsEnvSet "R" "wf:"
epicsEnvSet ("ENGINEER", "Petra Schwalbach")
cd "/home/epics/fug"
dbLoadDatabase "dbd/fug.dbd"
fug_registerRecordDeviceDriver pdbbase
#< ./iocBoot/$(IOC)/AutoSaveSetup.cmd
#Configure devices
drvAsynIPPortConfigure("L0","10.32.192.132:2101",0,0,0)    #FUG 202640102
# Debugging mode
#asynSetTraceMask(portName,addr,mask)
#asynSetTraceIOMask(portName,addr,mask)
#addr: In integer specifying the address of the device. For multiDevice ports a value of -1 means the port itself.
#mask: The mask value to set. See the mask bit definitions in asynDriver.h
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
## End Debugging mode
## Load record instances
#dbLoadTemplate "db/user.substitutions"
#dbLoadRecords "db/fugVersion.db", "user=schwalba"
#dbLoadRecords "db/dbSubExample.db", "user=schwalba"
dbLoadRecords("db/fug.db", "P=melba_020:, R=wf:, PORT=L0")
#dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=$(P)$(R)")
## pcMonitor
dbLoadRecords("/home/epics/synApps_6_1/support/iocStats-3-1-16/db/ioc.db", "IOCNAME=FUG-IOC-Status,TODFORMAT=%d.%m.%Y %H:%M:%S")
#var mySubDebug 1
#traceIocInit
cd "/home/epics/fug/iocBoot/iocfug"
iocInit
Starting iocInit
## EPICS R7.0.3.1
## EPICS Base built Nov  6 2019
#< AutoSaveTask.cmd
## Start any sequence programs
#seq sncExample, "user=schwalba"
It's comforting to know that there is nothing special to do about asynSetTrace.
There is no reason but time, why I use EPICS -7.0.3.1.
Petra
Am 11.05.2021 um 14:09 schrieb Mark Rivers:
Hi Petra,
If you configured your IOC as shown in that document then it should not matter which version of base you are running.
I add
to st.cmd, but nothing happens.
By "nothing happens" does that mean you got an error message when those asynSetTrace commands were executed, or just that there was no output from asynTrace.
Can you send the complete output when the IOC starts up and runs for several seconds?
From: Tech-talk <[email protected]> on behalf of Petra Schwalbach via Tech-talk <[email protected]>
Sent: Tuesday, May 11, 2021 5:02 AM
To: Mark Rivers via Tech-talk
Subject: asynSetTrace
Hello,
I want to use
I used EPICS 3.14.12.5 and I had no problems.
Now I use EPICS -7.0.3.1.
I configured my IOC like described in
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/creating-ioc.html<https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/creating-ioc.html?highlight=trace#creation-of-an-input-output-controller-ioc>
I add
My IOC is working.
Could it be that there is something to add to the xxxSupport.dbd file
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
something like registrar(drvAsynSetTraceCommands)?
Thank you for your efforts!
Best regards
Petra
Petra Schwalbach                            [email protected]<Petra%20Schwalbach>
Privat:
mobil 0151 58854122
Festnetz 06131 593275
Inst. f. Kernphysik, Uni Mainz          Tel.: 06131/39-25193
B1-Kollaboration                               Fax: 06131/39-22964
Johann-Joachim-Becher-Weg 45     http://portal.kph.uni-mainz.de/B1/
55099 Mainz
Privat:
mobil 0151 58854122
55099 Mainz
asynSetTrace Petra Schwalbach via Tech-talk
Re: asynSetTrace Mark Rivers via Tech-talk
Prev: Re: asynSetTrace Mark Rivers via Tech-talk
Next: Open Instrumentation & Controls Deputy Group Leader Position at LANL Pieck, Martin via Tech-talk
