Subject: Re: AreaDetector FrameType
From: "Jemian, Pete R. via Tech-talk" <[email protected]>
Date: Wed, 12 May 2021 17:04:53 +0000
Here's a Jupyter notebook with an example using Bluesky:
https://nbviewer.jupyter.org/github/BCDA-APS/use_bluesky/blob/main/lessons/sandbox/images_darks_flats.ipynb
On 5/12/2021 11:51 AM, Mark Rivers via Tech-talk wrote:
> Hi David,
> ØBut i can't find a description for how to use it in the docs or the code.
> ADFrameType is used to tell the driver what type of frame to collect:
> normal, background, flat field, etc.  This is mainly used by drivers
> that can perform the background and/or flat-field corrections in the
> vendor SDK, often using an FPGA.
> There appear to be 6 drivers that currently use ADFrameType.  This is a
> list of those drivers determined using “find”.
> corvette:~/devel/areaDetector>find . -name '*.cpp' -exec grep -H
> FrameType {} \;
> ./ADDexela/dexelaApp/src/Dexela.cpp:
> getIntegerParam(ADFrameType,         &frameType);
> ./ADDexela/dexelaApp/src/Dexela.cpp:    setIntegerParam(ADFrameType,
> ADFrameNormal);
> ADFrameBackground);
> ADFrameFlatField);
> ./ADBruker/brukerApp/src/BISDetector.cpp:
> ./ADPixirad/pixiradApp/src/pixirad.cpp:    status |=
> setIntegerParam(ADFrameType, FTOneColorLow);
> ./ADPixirad/pixiradApp/src/pixirad.cpp:    getIntegerParam(ADFrameType,
> &frameType);
> &frameType);
> ./ADPixirad/pixiradApp/src/pixirad.cpp:    } else if ((function ==
> ADFrameType) ||
> ./ADPCO/pcoApp/src/pco.cpp:  if (getIntParam(ADFrameType) ==
> ADFrameNormal)  // normal
> ./ADPCO/pcoApp/src/pco.cpp:  else if (getIntParam(ADFrameType) ==
> ADFrameBackground)  // dark
> ADFrameFlatField)  // white flood
> ./ADmarCCD/marCCDApp/src/marCCD.cpp:    getIntegerParam(ADFrameType,
> &frameType);
> &frameType);
> &frameType);
> ./ADPhotonII/PhotonIIApp/src/PhotonII.cpp:
> The Dexela and marCCD drivers are probably the best ones to look at.
> Mark
> *From:*Tech-talk <[email protected]> *On Behalf Of *David
> Vine via Tech-talk
> *Sent:* Wednesday, May 12, 2021 11:11 AM
> *To:* [email protected]
> *Subject:* AreaDetector FrameType
> Hi all,
> I see the frame type enum definition in ADCore:
> typedef enum
>      ADFrameNormal,          /**< Normal frame type */
>      ADFrameBackground,      /**< Background frame type */
>      ADFrameFlatField,       /**< Flat field (no sample) frame type */
>      ADFrameDoubleCorrelation      /**< Double correlation frame type,
> used to remove zingers */
> } ADFrameType_t
> Could someone point me to the documentation or an example?
> Thanks,
> David
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they are
> addressed. If you have received this email in error, please notify the
> system manager. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee, you should not disseminate, distribute or copy this email.
> Please notify the sender immediately by email if you have received this
> email by mistake and delete this email from your system. If you are not
> the intended recipient, you are notified that disclosing, copying,
> distributing or taking any action in reliance on the contents of this
> information is strictly prohibited
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
       Education is the one thing for which people
          are willing to pay yet not receive.
AreaDetector FrameType David Vine via Tech-talk
RE: AreaDetector FrameType Mark Rivers via Tech-talk
Prev: RE: AreaDetector FrameType Mark Rivers via Tech-talk
Next: Means of comparing alarm status with a conditional in a CALC record Wang, Andrew via Tech-talk
