Subject: RE: EPICS stopped
From: "Tagger, Jueri via Tech-talk" <[email protected]>
Date: Wed, 19 May 2021 17:16:47 +0000
Thanks to all for many good advices!
Juri
Kay wrote:
Well, good.
I would post that to tech talk, maybe somebody has an idea what's happening.
Or at least there's now a record in case it happens again.
Sure looks like several threads are stuck waiting for a semaphore:
Thread 84 (Thread 0x7f39b98b8700 (LWP 66431)):
#0  __lll_lock_wait () at ../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:135
#1  0x00007f3a03c74494 in _L_lock_952 () from /lib/x86_64-linux-gnu/libpthread.so.0
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978038770) at ../nptl/pthread_mutex_lock.c:114
#3  0x00007f3a04a99fb6 in epicsMutexOsdLock () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a04f8887d in casAccessRightsCB () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04a76f7e in asComputePvt.part.1 () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#6  0x00007f3a04a77127 in asComputeAsgPvt.part.2 () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#7  0x00007f3a04a77868 in asComputeAsg () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#8  0x00007f3a04d10bc0 in oldSubscription::current(epicsGuard<epicsMutex>&, unsigned int, unsigned long, void const*) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#9  0x00007f3a04cef017 in cac::eventRespAction(callbackManager&, tcpiiu&, epicsTime const&, caHdrLargeArray const&, void*) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#10 0x00007f3a04d07616 in tcpiiu::processIncoming(epicsTime const&, callbackManager&) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#11 0x00007f3a04d098aa in tcpRecvThread::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#12 0x00007f3a04a92089 in epicsThreadCallEntryPoint () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#13 0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#14 0x00007f3a03c72064 in start_thread (arg=0x7f39b98b8700) at pthread_create.c:309
#15 0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
--> Trying to re-compute access security?
Thread 142 (Thread 0x7f3a0222f700 (LWP 453879)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x1771580) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f4c01b in dbScanLock () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f5cbdc in scanList () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04f5cd2f in ioscanCallback () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04f66e05 in callbackTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#8  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#9  0x00007f3a03c72064 in start_thread (arg=0x7f3a0222f700) at pthread_create.c:309
#10 0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
--> Trying to scan some record?
#5  0x00007f3a04f647d1 in dbChannel_get_count () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04f8ad52 in read_notify_action () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04f8b72e in camessage () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#8  0x00007f3a04f881e3 in camsgtask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#9  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#10 0x00007f3a03c72064 in start_thread (arg=0x7f394adf3700) at pthread_create.c:309
#11 0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
--> Trying to reply to a CA read, about to lock the channel to get the data size (element count)?
-Kay
Sent: Wednesday, May 19, 2021 12:19 PM
To: Tagger, Jueri <[email protected]>
Cc: [email protected]
Is this Linux or some other OS?
It looks like you will need to kill the IOC process.
Sent: Wednesday, May 19, 2021 11:15 AM
No effect from ^C whatsoever. Typed epicsMutexShowAll 1
3 times to blank screen – no response
Sent: Wednesday, May 19, 2021 12:12 PM
Can you type ^C to abort the casr command?  It could be a deadlock.  If that works then type
epicsMutexShowAll 1
several times and see if the same mutexes are always locked.   That is the symptom of a deadlock.
From: Tech-talk <[email protected]> On Behalf Of Tagger, Jueri via Tech-talk
Sent: Wednesday, May 19, 2021 11:04 AM
To: [email protected]
Subject: EPICS stopped
We have suddenly situation we can no longer connect to ca channels, (while the existing connections are served)
casr 4
181888 bytes allocated
       Send Lock:
           epicsMutexId 0x7f3978036420 source ../../../src/ioc/rsrv/caservertask.c line 1231
       Put Notify Lock:
           epicsMutexId 0x7f3978036450 source ../../../src/ioc/rsrv/caservertask.c line 1232
       Address Queue Lock:
           epicsMutexId 0x7f3978036480 source ../../../src/ioc/rsrv/caservertask.c line 1233
       Event Queue Lock:
           epicsMutexId 0x7f39780364b0 source ../../../src/ioc/rsrv/caservertask.c line 1234
       Block Semaphore:
           epicsEvent 0x7f3978010c90: full
    pthread_mutex = 0x7f3978010c90, pthread_cond = 0x7f3978010cb8
    TCP client at 10.0.153.12:54302 'box64-3':
       User 'rose', V4.13, Priority = 0, 75 Channels
       Task Id = 0x7f397803c750, Socket FD = 44
       2262.05 secs since last send, 2262.04 secs since last receive
       Unprocessed request bytes = 424, Undelivered response bytes = 0
       State = up
Then the output stopped …. no response any more on the console
EPICS_BASE=base-3.15.8
Any ideas?
J. Tagger
NSLS-II=
Thread 146 (Thread 0x7f3a06b70700 (LWP 453870)):
#0  pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S:185
#1  0x00007f3a04a9a47b in epicsEventWait () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#2  0x00007f3a04a934c9 in epicsEventMustWait () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04a819e5 in errlogThread () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a06b70700) at pthread_create.c:309
#6  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 145 (Thread 0x7f3a06aef700 (LWP 453872)):
#0  pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238
#1  0x00007f3a04a9a609 in epicsEventWaitWithTimeout () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#2  0x00007f3a04a9339c in epicsEvent::wait(double) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04aa2f15 in timerQueueActive::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a04a92089 in epicsThreadCallEntryPoint () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#5  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#6  0x00007f3a03c72064 in start_thread (arg=0x7f3a06aef700) at pthread_create.c:309
#7  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 144 (Thread 0x7f3a023b1700 (LWP 453877)):
#2  0x00007f3a04a9ffe4 in twdTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f3a023b1700) at pthread_create.c:309
#5  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 143 (Thread 0x7f3a02330700 (LWP 453878)):
#6  0x00007f3a03c72064 in start_thread (arg=0x7f3a02330700) at pthread_create.c:309
Thread 141 (Thread 0x7f3a0202e700 (LWP 453880)):
#3  0x00007f3a04f66e39 in callbackTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a0202e700) at pthread_create.c:309
Thread 140 (Thread 0x7f3a01e2d700 (LWP 453881)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a01e2d700) at pthread_create.c:309
Thread 139 (Thread 0x7f3a01c2c700 (LWP 453882)):
#3  0x00007f3a04f684fc in dbCaTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a01c2c700) at pthread_create.c:309
Thread 138 (Thread 0x7f3a01a2b700 (LWP 453883)):
#0  0x00007f3a03f40f2d in nanosleep () at ../sysdeps/unix/syscall-template.S:81
#1  0x00007f3a04a98d70 in epicsThreadSleep () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#2  0x00007f3a0677b379 in s7plcMain () from /epics/iocs/SR-Cry/lib/linux-x86_64/libsrCrySupport.so
#4  0x00007f3a03c72064 in start_thread (arg=0x7f3a01a2b700) at pthread_create.c:309
Thread 137 (Thread 0x7f3a0182a700 (LWP 453884)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x182b0e0) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f855f9 in casStatsFetch () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a05c37e29 in scan_time () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/iocStats/lib/linux-x86_64/libdevIocStats.so
#6  0x00007f3a04aa107e in epicsTimerForC::expire(epicsTime const&) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#7  0x00007f3a04aa27be in timerQueue::process(epicsTime const&) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#8  0x00007f3a04aa2f09 in timerQueueActive::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#9  0x00007f3a04a92089 in epicsThreadCallEntryPoint () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#10 0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#11 0x00007f3a03c72064 in start_thread (arg=0x7f3a0182a700) at pthread_create.c:309
#12 0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 136 (Thread 0x7f3a01729700 (LWP 453885)):
#0  0x00007f3a03f68893 in select () at ../sysdeps/unix/syscall-template.S:81
#1  0x00007f3a0677baca in s7plcReceiveThread () from /epics/iocs/SR-Cry/lib/linux-x86_64/libsrCrySupport.so
#2  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a01729700) at pthread_create.c:309
#4  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 135 (Thread 0x7f3a01528700 (LWP 453886)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a01528700) at pthread_create.c:309
Thread 134 (Thread 0x7f3a01327700 (LWP 453887)):
#3  0x00007f3a0677be6c in s7plcSendThread () from /epics/iocs/SR-Cry/lib/linux-x86_64/libsrCrySupport.so
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a01327700) at pthread_create.c:309
Thread 133 (Thread 0x7f3a01126700 (LWP 453888)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a01126700) at pthread_create.c:309
Thread 132 (Thread 0x7f3a00f25700 (LWP 453889)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a00f25700) at pthread_create.c:309
Thread 131 (Thread 0x7f3a00d24700 (LWP 453890)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a00d24700) at pthread_create.c:309
Thread 130 (Thread 0x7f3a00b23700 (LWP 453891)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a00b23700) at pthread_create.c:309
Thread 129 (Thread 0x7f3a00922700 (LWP 453892)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a00922700) at pthread_create.c:309
Thread 128 (Thread 0x7f3a00721700 (LWP 453893)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a00721700) at pthread_create.c:309
Thread 127 (Thread 0x7f3a00520700 (LWP 453894)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a00520700) at pthread_create.c:309
Thread 126 (Thread 0x7f3a0031f700 (LWP 453895)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a0031f700) at pthread_create.c:309
Thread 125 (Thread 0x7f39bbfff700 (LWP 453896)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39bbfff700) at pthread_create.c:309
Thread 124 (Thread 0x7f39bbdfe700 (LWP 453897)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39bbdfe700) at pthread_create.c:309
Thread 123 (Thread 0x7f39bbbfd700 (LWP 453898)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39bbbfd700) at pthread_create.c:309
Thread 122 (Thread 0x7f39bb9fc700 (LWP 453899)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39bb9fc700) at pthread_create.c:309
Thread 121 (Thread 0x7f39bb7fb700 (LWP 453900)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39bb7fb700) at pthread_create.c:309
Thread 120 (Thread 0x7f39bb5fa700 (LWP 453901)):
#3  0x00007f3a04f5cd90 in onceTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39bb5fa700) at pthread_create.c:309
Thread 119 (Thread 0x7f39bb3f9700 (LWP 453902)):
#2  0x00007f3a04f5cebb in periodicTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39bb3f9700) at pthread_create.c:309
Thread 118 (Thread 0x7f39bb1f8700 (LWP 453903)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39bb1f8700) at pthread_create.c:309
Thread 117 (Thread 0x7f39baff7700 (LWP 453904)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39baff7700) at pthread_create.c:309
Thread 116 (Thread 0x7f39badf6700 (LWP 453905)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39badf6700) at pthread_create.c:309
Thread 115 (Thread 0x7f39babf5700 (LWP 453906)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39babf5700) at pthread_create.c:309
Thread 114 (Thread 0x7f39ba9f4700 (LWP 453907)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39ba9f4700) at pthread_create.c:309
Thread 113 (Thread 0x7f39ba7f3700 (LWP 453908)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39ba7f3700) at pthread_create.c:309
Thread 112 (Thread 0x7f39ba5f2700 (LWP 453916)):
#3  0x00007f3a04f4aeb4 in asCaTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39ba5f2700) at pthread_create.c:309
Thread 111 (Thread 0x7f39ba3f1700 (LWP 453917)):
#2  0x00007f3a04a9334c in epicsEvent::wait() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04a8fbb2 in (anonymous namespace)::ipAddrToAsciiGlobal::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#6  0x00007f3a03c72064 in start_thread (arg=0x7f39ba3f1700) at pthread_create.c:309
Thread 110 (Thread 0x7f3a0011e700 (LWP 453918)):
#6  0x00007f3a03c72064 in start_thread (arg=0x7f3a0011e700) at pthread_create.c:309
Thread 109 (Thread 0x7f39b99b9700 (LWP 453919)):
#0  0x00007f3a03f70543 in recvfrom () at ../sysdeps/unix/syscall-template.S:81
#1  0x00007f3a04d0226c in udpRecvThread::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#2  0x00007f3a04a92089 in epicsThreadCallEntryPoint () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39b99b9700) at pthread_create.c:309
Thread 108 (Thread 0x7f39b9118700 (LWP 453922)):
#4  0x00007f3a04f87ff7 in req_server () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a03c72064 in start_thread (arg=0x7f39b9118700) at pthread_create.c:309
Thread 107 (Thread 0x7f39b9017700 (LWP 453923)):
#1  0x00007f3a04f8d296 in cast_server () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39b9017700) at pthread_create.c:309
Thread 106 (Thread 0x7f39b8f16700 (LWP 453924)):
#2  0x00007f3a04f8d6cb in rsrv_online_notify_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39b8f16700) at pthread_create.c:309
Thread 105 (Thread 0x7f39b8e95700 (LWP 453925)):
#1  0x00007f3a05809818 in shWaitFor () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#2  0x00007f3a05809c8e in shRecvExact () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#3  0x00007f3a0580a58d in casterRecvPMsg () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#4  0x00007f3a0580ae5f in doCasterTCPPhase () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#5  0x00007f3a0580a41a in casterThread () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#6  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#7  0x00007f3a03c72064 in start_thread (arg=0x7f39b8e95700) at pthread_create.c:309
#8  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 104 (Thread 0x7f39b8e14700 (LWP 453928)):
#2  0x00007f3a04a9bc1c in epicsMessageQueueReceiveWithTimeout () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a05a22f9e in save_restore () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/autosave-R5-10/lib/linux-x86_64/libautosave.so
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b8e14700) at pthread_create.c:309
Thread 103 (Thread 0x7f39b8c13700 (LWP 453929)):
#2  0x00007f3a04a8abac in logClientRestart () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39b8c13700) at pthread_create.c:309
Thread 102 (Thread 0x7f39b8b92700 (LWP 453930)):
#3  0x00007f3a06076ebe in caPutLogTask () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/caPutLog-3.6/lib/linux-x86_64/libcaPutLog.so
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b8b92700) at pthread_create.c:309
Thread 101 (Thread 0x7f39b8ad0700 (LWP 453931)):
#3  0x00007f3a04f6018c in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b8ad0700) at pthread_create.c:309
Thread 100 (Thread 0x7f39b89cf700 (LWP 453932)):
#0  0x00007f3a03f704db in __libc_recv (fd=5, buf=0x7f39b8b09010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#1  0x00007f3a04f881bd in camsgtask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39b89cf700) at pthread_create.c:309
Thread 99 (Thread 0x7f39b87ce700 (LWP 453933)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b87ce700) at pthread_create.c:309
Thread 98 (Thread 0x7f39b86cd700 (LWP 453934)):
#0  0x00007f3a03f704db in __libc_recv (fd=29, buf=0x7f39b8b01010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39b86cd700) at pthread_create.c:309
Thread 97 (Thread 0x7f39b84cc700 (LWP 453935)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b84cc700) at pthread_create.c:309
Thread 96 (Thread 0x7f39b83cb700 (LWP 453936)):
#0  0x00007f3a03f704db in __libc_recv (fd=30, buf=0x7f39b8af9010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39b83cb700) at pthread_create.c:309
Thread 95 (Thread 0x7f394b7fa700 (LWP 453962)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394b7fa700) at pthread_create.c:309
Thread 94 (Thread 0x7f394b6f9700 (LWP 453964)):
#0  0x00007f3a03f704db in __libc_recv (fd=34, buf=0x7f39b8ad9010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394b6f9700) at pthread_create.c:309
Thread 93 (Thread 0x7f394955b700 (LWP 454593)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394955b700) at pthread_create.c:309
Thread 92 (Thread 0x7f394945a700 (LWP 454594)):
#0  0x00007f3a03f704db in __libc_recv (fd=45, buf=0x7f39b8078010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394945a700) at pthread_create.c:309
Thread 91 (Thread 0x7f3948c55700 (LWP 454622)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3948c55700) at pthread_create.c:309
Thread 90 (Thread 0x7f394824e700 (LWP 454708)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394824e700) at pthread_create.c:309
Thread 89 (Thread 0x7f38a7fff700 (LWP 454709)):
#0  0x00007f3a03f704db in __libc_recv (fd=51, buf=0x7f39b8048010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a7fff700) at pthread_create.c:309
Thread 88 (Thread 0x7f3948550700 (LWP 67572)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3948550700) at pthread_create.c:309
Thread 87 (Thread 0x7f394844f700 (LWP 67573)):
#0  0x00007f3a03f704db in __libc_recv (fd=58, buf=0x7f39b8054010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394844f700) at pthread_create.c:309
Thread 86 (Thread 0x7f3949259700 (LWP 275248)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3949259700) at pthread_create.c:309
Thread 85 (Thread 0x7f3949158700 (LWP 275249)):
#0  0x00007f3a03f704db in __libc_recv (fd=46, buf=0x7f39b8070010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3949158700) at pthread_create.c:309
Thread 83 (Thread 0x7f39b96b7700 (LWP 66432)):
#3  0x00007f3a04d09426 in tcpSendThread::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#6  0x00007f3a03c72064 in start_thread (arg=0x7f39b96b7700) at pthread_create.c:309
Thread 82 (Thread 0x7f394abf2700 (LWP 334972)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394abf2700) at pthread_create.c:309
Thread 81 (Thread 0x7f394aaf1700 (LWP 334973)):
#0  0x00007f3a03f704db in __libc_recv (fd=47, buf=0x7f39b80b5010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394aaf1700) at pthread_create.c:309
Thread 80 (Thread 0x7f394b1f6700 (LWP 239993)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394b1f6700) at pthread_create.c:309
Thread 79 (Thread 0x7f394b0f5700 (LWP 239994)):
#0  0x00007f3a03f704db in __libc_recv (fd=36, buf=0x7f39b80c5010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394b0f5700) at pthread_create.c:309
Thread 78 (Thread 0x7f38a6cf3700 (LWP 16214)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a6cf3700) at pthread_create.c:309
Thread 77 (Thread 0x7f38a6bf2700 (LWP 16215)):
#0  0x00007f3a03f704db in __libc_recv (fd=20, buf=0x7f3948119010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a6bf2700) at pthread_create.c:309
Thread 76 (Thread 0x7f3948f57700 (LWP 401666)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3948f57700) at pthread_create.c:309
Thread 75 (Thread 0x7f3948e56700 (LWP 401667)):
#0  0x00007f3a03f704db in __libc_recv (fd=38, buf=0x7f39b806c010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3948e56700) at pthread_create.c:309
Thread 74 (Thread 0x7f3949ce8700 (LWP 171745)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3949ce8700) at pthread_create.c:309
Thread 73 (Thread 0x7f3949be7700 (LWP 171746)):
#0  0x00007f3a03f704db in __libc_recv (fd=31, buf=0x7f39b8089010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3949be7700) at pthread_create.c:309
Thread 72 (Thread 0x7f38a78fb700 (LWP 314606)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a78fb700) at pthread_create.c:309
Thread 71 (Thread 0x7f38a77fa700 (LWP 314607)):
#0  0x00007f3a03f704db in __libc_recv (fd=33, buf=0x7f3948135010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a77fa700) at pthread_create.c:309
Thread 70 (Thread 0x7f394bdfe700 (LWP 310386)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394bdfe700) at pthread_create.c:309
Thread 69 (Thread 0x7f394bcfd700 (LWP 310387)):
#0  0x00007f3a03f704db in __libc_recv (fd=35, buf=0x7f39b8ae9010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394bcfd700) at pthread_create.c:309
Thread 68 (Thread 0x7f38a75f9700 (LWP 283802)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a75f9700) at pthread_create.c:309
Thread 67 (Thread 0x7f38a74f8700 (LWP 283803)):
#0  0x00007f3a03f704db in __libc_recv (fd=40, buf=0x7f394812d010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a74f8700) at pthread_create.c:309
Thread 66 (Thread 0x7f394810c700 (LWP 380296)):
#0  0x00007f3a03f7064b in __libc_send (fd=41, buf=0x7f3948145010, n=200, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/send.c:31
#1  0x00007f3a04f84d5a in cas_send_bs_msg () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#2  0x00007f3a04f89338 in read_reply () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#3  0x00007f3a04f60317 in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394810c700) at pthread_create.c:309
Thread 65 (Thread 0x7f38a7dfe700 (LWP 380297)):
#0  0x00007f3a03f704db in __libc_recv (fd=41, buf=0x7f3948149010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a7dfe700) at pthread_create.c:309
Thread 64 (Thread 0x7f38a69f1700 (LWP 14863)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a69f1700) at pthread_create.c:309
Thread 63 (Thread 0x7f38a68f0700 (LWP 14864)):
#0  0x00007f3a03f704db in __libc_recv (fd=37, buf=0x7f394810d010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a68f0700) at pthread_create.c:309
Thread 62 (Thread 0x7f39b81ca700 (LWP 82076)):
#6  0x00007f3a04f892c6 in read_reply () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04f60317 in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#9  0x00007f3a03c72064 in start_thread (arg=0x7f39b81ca700) at pthread_create.c:309
Thread 61 (Thread 0x7f394bfff700 (LWP 82077)):
#2  0x00007f3a04a96c7d in epicsAssert () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04f5fedb in db_queue_event_log () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#4  0x00007f3a04f6012d in db_post_single_event () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f8a1e1 in event_add_action () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04f8b72e in camessage () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04f881e3 in camsgtask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#9  0x00007f3a03c72064 in start_thread (arg=0x7f394bfff700) at pthread_create.c:309
Thread 60 (Thread 0x7f38a7bfd700 (LWP 266698)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a7bfd700) at pthread_create.c:309
Thread 59 (Thread 0x7f38a7afc700 (LWP 266699)):
#0  0x00007f3a03f704db in __libc_recv (fd=9, buf=0x7f394813d010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a7afc700) at pthread_create.c:309
Thread 58 (Thread 0x7f394a8f0700 (LWP 122817)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394a8f0700) at pthread_create.c:309
Thread 57 (Thread 0x7f394a7ef700 (LWP 122818)):
#0  0x00007f3a03f704db in __libc_recv (fd=43, buf=0x7f39b80ad010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394a7ef700) at pthread_create.c:309
Thread 56 (Thread 0x7f394bafc700 (LWP 263620)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394bafc700) at pthread_create.c:309
Thread 55 (Thread 0x7f394b9fb700 (LWP 263621)):
#0  0x00007f3a03f704db in __libc_recv (fd=39, buf=0x7f39b8ae1010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394b9fb700) at pthread_create.c:309
Thread 54 (Thread 0x7f394a5ee700 (LWP 388381)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394a5ee700) at pthread_create.c:309
Thread 53 (Thread 0x7f394a4ed700 (LWP 388382)):
#0  0x00007f3a03f704db in __libc_recv (fd=52, buf=0x7f39b80a5010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394a4ed700) at pthread_create.c:309
Thread 52 (Thread 0x7f394aef4700 (LWP 253440)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f397800eef0) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f8c716 in claim_ciu_reply () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f8ce8a in rsrv_extra_labor () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04f601de in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#8  0x00007f3a03c72064 in start_thread (arg=0x7f394aef4700) at pthread_create.c:309
#9  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 51 (Thread 0x7f394adf3700 (LWP 253441)):
Thread 50 (Thread 0x7f38a66ae700 (LWP 103788)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978043e30) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f891a5 in read_reply () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f60317 in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a03c72064 in start_thread (arg=0x7f38a66ae700) at pthread_create.c:309
Thread 49 (Thread 0x7f38a65ad700 (LWP 103789)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f38a65ad700) at pthread_create.c:309
Thread 48 (Thread 0x7f3948852700 (LWP 235726)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978038690) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f8cf11 in rsrv_extra_labor () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f601de in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a03c72064 in start_thread (arg=0x7f3948852700) at pthread_create.c:309
Thread 47 (Thread 0x7f3948751700 (LWP 235727)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f3948751700) at pthread_create.c:309
Thread 46 (Thread 0x7f38a72f7700 (LWP 312192)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f397801ab10) at ../nptl/pthread_mutex_lock.c:114
#7  0x00007f3a03c72064 in start_thread (arg=0x7f38a72f7700) at pthread_create.c:309
Thread 45 (Thread 0x7f38a71f6700 (LWP 312193)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f38a71f6700) at pthread_create.c:309
Thread 44 (Thread 0x7f3a028b0700 (LWP 314016)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a028b0700) at pthread_create.c:309
Thread 43 (Thread 0x7f3a027af700 (LWP 314017)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f3a027af700) at pthread_create.c:309
Thread 42 (Thread 0x7f3949fea700 (LWP 314553)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3949fea700) at pthread_create.c:309
Thread 41 (Thread 0x7f3949ee9700 (LWP 314554)):
#0  0x00007f3a03f704db in __libc_recv (fd=60, buf=0x7f39b8091010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3949ee9700) at pthread_create.c:309
Thread 40 (Thread 0x7f3a02bb2700 (LWP 318443)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a02bb2700) at pthread_create.c:309
Thread 39 (Thread 0x7f3a02ab1700 (LWP 318444)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f3a02ab1700) at pthread_create.c:309
Thread 38 (Thread 0x7f394b4f8700 (LWP 319105)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978045930) at ../nptl/pthread_mutex_lock.c:114
#7  0x00007f3a03c72064 in start_thread (arg=0x7f394b4f8700) at pthread_create.c:309
Thread 37 (Thread 0x7f394b3f7700 (LWP 319106)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f394b3f7700) at pthread_create.c:309
Thread 36 (Thread 0x7f394a2ec700 (LWP 319383)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978045eb0) at ../nptl/pthread_mutex_lock.c:114
#7  0x00007f3a03c72064 in start_thread (arg=0x7f394a2ec700) at pthread_create.c:309
Thread 35 (Thread 0x7f394a1eb700 (LWP 319384)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f394a1eb700) at pthread_create.c:309
Thread 34 (Thread 0x7f3a025ae700 (LWP 389012)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a025ae700) at pthread_create.c:309
Thread 33 (Thread 0x7f39499e6700 (LWP 389013)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x1808150) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04a77386 in asAddClient () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#5  0x00007f3a04f8c95c in claim_ciu_action () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#9  0x00007f3a03c72064 in start_thread (arg=0x7f39499e6700) at pthread_create.c:309
Thread 32 (Thread 0x7f39497e5700 (LWP 390381)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39497e5700) at pthread_create.c:309
Thread 31 (Thread 0x7f3948b54700 (LWP 390382)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f3948b54700) at pthread_create.c:309
Thread 30 (Thread 0x7f3948953700 (LWP 391765)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3948953700) at pthread_create.c:309
Thread 29 (Thread 0x7f38a6ff5700 (LWP 391766)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a6ff5700) at pthread_create.c:309
Thread 28 (Thread 0x7f38a6df4700 (LWP 392248)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a6df4700) at pthread_create.c:309
Thread 27 (Thread 0x7f38a63ac700 (LWP 392249)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a63ac700) at pthread_create.c:309
Thread 26 (Thread 0x7f38a61ab700 (LWP 393036)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a61ab700) at pthread_create.c:309
Thread 25 (Thread 0x7f38a60aa700 (LWP 393037)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a60aa700) at pthread_create.c:309
Thread 24 (Thread 0x7f38a5ea9700 (LWP 394387)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a5ea9700) at pthread_create.c:309
Thread 23 (Thread 0x7f38a5da8700 (LWP 394388)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a5da8700) at pthread_create.c:309
Thread 22 (Thread 0x7f38a5ba7700 (LWP 395812)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a5ba7700) at pthread_create.c:309
Thread 21 (Thread 0x7f38a5aa6700 (LWP 395813)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a5aa6700) at pthread_create.c:309
Thread 20 (Thread 0x7f38a58a5700 (LWP 397184)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a58a5700) at pthread_create.c:309
Thread 19 (Thread 0x7f38a57a4700 (LWP 397185)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a57a4700) at pthread_create.c:309
Thread 18 (Thread 0x7f38a55a3700 (LWP 398551)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a55a3700) at pthread_create.c:309
Thread 17 (Thread 0x7f38a54a2700 (LWP 398552)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a54a2700) at pthread_create.c:309
Thread 16 (Thread 0x7f38a52a1700 (LWP 399894)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a52a1700) at pthread_create.c:309
Thread 15 (Thread 0x7f38a51a0700 (LWP 399895)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a51a0700) at pthread_create.c:309
Thread 14 (Thread 0x7f38a4f9f700 (LWP 399973)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a4f9f700) at pthread_create.c:309
Thread 13 (Thread 0x7f38a4e9e700 (LWP 399974)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a4e9e700) at pthread_create.c:309
Thread 12 (Thread 0x7f38a4c9d700 (LWP 400630)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a4c9d700) at pthread_create.c:309
Thread 11 (Thread 0x7f38a4b9c700 (LWP 400631)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a4b9c700) at pthread_create.c:309
Thread 10 (Thread 0x7f38a499b700 (LWP 401320)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a499b700) at pthread_create.c:309
Thread 9 (Thread 0x7f38a489a700 (LWP 401321)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a489a700) at pthread_create.c:309
Thread 8 (Thread 0x7f38a4699700 (LWP 402224)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a4699700) at pthread_create.c:309
Thread 7 (Thread 0x7f38a4598700 (LWP 402225)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a4598700) at pthread_create.c:309
Thread 6 (Thread 0x7f38a4397700 (LWP 402692)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a4397700) at pthread_create.c:309
Thread 5 (Thread 0x7f38a4296700 (LWP 402693)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a4296700) at pthread_create.c:309
Thread 4 (Thread 0x7f382bfff700 (LWP 404260)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f382bfff700) at pthread_create.c:309
Thread 3 (Thread 0x7f382befe700 (LWP 404261)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f382befe700) at pthread_create.c:309
Thread 2 (Thread 0x7f382bcfd700 (LWP 405627)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f382bcfd700) at pthread_create.c:309
Thread 1 (Thread 0x7f3a06b72740 (LWP 453868)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f397800efd0) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f85a2b in log_one_client () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f85e73 in casr () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04a88829 in iocshBody () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#7  0x0000000000406626 in main ()
jtagger@linde-sm1:/epics/iocs/SR-Cry$
Re: EPICS stopped Michael Davidsaver via Tech-talk
EPICS stopped Tagger, Jueri via Tech-talk
RE: EPICS stopped Mark Rivers via Tech-talk
RE: EPICS stopped Tagger, Jueri via Tech-talk
Prev: Re: EPICS stopped Sinclair, John via Tech-talk
Next: Re: EPICS stopped Michael Davidsaver via Tech-talk
