Subject: RE: EPICS stopped
To: "'Tagger, Jueri'" <[email protected]>
Date: Wed, 19 May 2021 16:18:37 +0000
Is this Linux or some other OS?
It looks like you will need to kill the IOC process.
Sent: Wednesday, May 19, 2021 11:15 AM
Cc: [email protected]
No effect from ^C whatsoever. Typed epicsMutexShowAll 1
3 times to blank screen – no response
Sent: Wednesday, May 19, 2021 12:12 PM
To: Tagger, Jueri <[email protected]>
Can you type ^C to abort the casr command?  It could be a deadlock.  If that works then type
epicsMutexShowAll 1
several times and see if the same mutexes are always locked.   That is the symptom of a deadlock.
From: Tech-talk <[email protected]> On Behalf Of Tagger, Jueri via Tech-talk
Sent: Wednesday, May 19, 2021 11:04 AM
To: [email protected]
Subject: EPICS stopped
We have suddenly situation we can no longer connect to ca channels, (while the existing connections are served)
casr 4
181888 bytes allocated
       Send Lock:
           epicsMutexId 0x7f3978036420 source ../../../src/ioc/rsrv/caservertask.c line 1231
       Put Notify Lock:
           epicsMutexId 0x7f3978036450 source ../../../src/ioc/rsrv/caservertask.c line 1232
       Address Queue Lock:
           epicsMutexId 0x7f3978036480 source ../../../src/ioc/rsrv/caservertask.c line 1233
       Event Queue Lock:
           epicsMutexId 0x7f39780364b0 source ../../../src/ioc/rsrv/caservertask.c line 1234
       Block Semaphore:
           epicsEvent 0x7f3978010c90: full
    pthread_mutex = 0x7f3978010c90, pthread_cond = 0x7f3978010cb8
    TCP client at 10.0.153.12:54302 'box64-3':
       User 'rose', V4.13, Priority = 0, 75 Channels
       Task Id = 0x7f397803c750, Socket FD = 44
       2262.05 secs since last send, 2262.04 secs since last receive
       Unprocessed request bytes = 424, Undelivered response bytes = 0
       State = up
Then the output stopped …. no response any more on the console
EPICS_BASE=base-3.15.8
Any ideas?
J. Tagger
NSLS-II=
Re: EPICS stopped Sinclair, John via Tech-talk
RE: EPICS stopped Tagger, Jueri via Tech-talk
RE: EPICS stopped Mark Rivers via Tech-talk
Prev: RE: EPICS stopped Tagger, Jueri via Tech-talk
Next: Re: EPICS stopped Sinclair, John via Tech-talk
