Subject: asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux
To: Tech talk <[email protected]>
Date: Thu, 20 May 2021 16:22:28 +0200
I am in the process of cross-compiling EPICS7 for powerpc64-fsl-linux.
epics-base works great, also already some support-modules like sncseq, sscan, calc, busy …
Now I just fail with asyn on the vxi11 part.
rpc/rpc.h can only be found on the yocto-sysroot under usr/include/tirpc. Also I don't see any rpc-support like rpcgen etc..
That may also be due to how it was built with yocto. But this part I have not yet understood and I use
recipes from ESS and am quite happy where I have now arrived with their help ;-)
/opt/ifc14xx/2.6-4.14/sysroots/x86_64-fslsdk-linux/usr/bin/powerpc64-fsl-linux/powerpc64-fsl-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API   -D_ppc_64_ --sysroot=/opt/ifc14xx/2.6-4.14/sysroots/ppc64e6500-fsl-linux -mhard-float -mcpu=e6500  -DUNIX  -Dlinux      -O3   -Wall -Werror-implicit-function-declaration     -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC -DHAVE_CALCMOD -DHAVE_DEVINT64   -m64 --sysroot=/opt/ifc14xx/2.6-4.14/sysroots/ppc64e6500-fsl-linux -mhard-float -mcpu=e6500 -pipe -feliminate-unused-debug-types      -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         -I/home/yocto/EPICS/epics-support/seq-2.2.8/include -I/home/yocto/EPICS/epics-base/include/compiler/gcc -I/home/yocto/EPICS/epics-base/include/os/Linux -I/home/yocto/EPICS/epics-base/include   -I/home/yocto/EPICS/epics-support/sscan/include   -I/home/yocto/EPICS/epics-support/calc/include  -I/home/yocto/EPICS/epics-support/autosave/include/os/Linux -I/home/yocto/EPICS/epics-support/autosave/include   -I/home/yocto/EPICS/epics-support/busy/include         -I/home/yocto/EPICS/epics-support/motor/include           -c vxi11core_xdr.c
In file included from vxi11core_xdr.c:6:
vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory
#include <rpc/rpc.h>
compilation terminated.
Is there a variable/flag I can use to keep the vxi11 stuff out of the build process of asyn?
Danke Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
RE: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Pearson, Matthew R. via Tech-talk
Prev: Linux memory problems/questions Mark Rivers via Tech-talk
Next: RE: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Pearson, Matthew R. via Tech-talk
Prev: Re: Linux memory problems/questions Michael Davidsaver via Tech-talk
