I think I came across the same issue recently on RHEL8. There was a recent Asyn build option added, that you can set in CONFIG_SITE (or CONFIG_SITE.local):
TIRPC=YES
Which changes the include file search path to /usr/include/tirpc/
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of junkes via Tech-talk
Sent: Thursday, May 20, 2021 10:22 AM
To: Tech talk <[email protected]>
Subject: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux
I am in the process of cross-compiling EPICS7 for powerpc64-fsl-linux.
epics-base works great, also already some support-modules like sncseq, sscan, calc, busy …
Now I just fail with asyn on the vxi11 part.
rpc/rpc.h can only be found on the yocto-sysroot under usr/include/tirpc. Also I don't see any rpc-support like rpcgen etc..
That may also be due to how it was built with yocto. But this part I have not yet understood and I use
recipes from ESS and am quite happy where I have now arrived with their help ;-)
/opt/ifc14xx/2.6-4.14/sysroots/x86_64-fslsdk-linux/usr/bin/powerpc64-fsl-linux/powerpc64-fsl-linux-gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API -D_ppc_64_ --sysroot=/opt/ifc14xx/2.6-4.14/sysroots/ppc64e6500-fsl-linux -mhard-float -mcpu=e6500 -DUNIX -Dlinux -O3 -Wall -Werror-implicit-function-declaration -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC -DHAVE_CALCMOD -DHAVE_DEVINT64 -m64 --sysroot=/opt/ifc14xx/2.6-4.14/sysroots/ppc64e6500-fsl-linux -mhard-float -mcpu=e6500 -pipe -feliminate-unused-debug-types -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/home/yocto/EPICS/epics-support/seq-2.2.8/include -I/home/yocto/EPICS/epics-base/include/compiler/gcc -I/home/yocto/EPICS/epics-base/include/os/Linux -I/home/yocto/EPICS/epics-base/include -I/home/yocto/EPICS/epics-support/sscan/include -I/home/yocto/EPICS/epics-support/calc/include -I/home/yocto/EPICS/epics-support/autosave/include/os/Linux -I/home/yocto/EPICS/epics-support/autosave/include -I/home/yocto/EPICS/epics-support/busy/include -I/home/yocto/EPICS/epics-support/motor/include -c vxi11core_xdr.c
In file included from vxi11core_xdr.c:6:
vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory
#include <rpc/rpc.h>
compilation terminated.
Is there a variable/flag I can use to keep the vxi11 stuff out of the build process of asyn?
Danke Heinz
- Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Hu, Yong via Tech-talk
- asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux junkes via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
