Subject: SNMP in EPICS
From: Tomasz Brys via Tech-talk <[email protected]>
Date: Fri, 21 May 2021 08:13:06 +0000
I have a problem how to implement SNMP protocol in EPICS.
I want to keep MIB file somewhere in the module, not in the /usr/share/snmp directory.
If I run snmpwalk I can:
snmpwalk -v2c -M +/vagrant/modules/e3-M300_GPS/M300_GPS/M300_GPSApp/MBG-SNMP-MIB -m All -c comm 192.168.XXX.XXX MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState
and I get output:
MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState.1 = INTEGER: synchronized(1)
How should I define my record in Db?
I did it like that:
record(longin, "$(P)$(R)RefclockState"){
  field(DESC, "Status of GPS refclock")
  field(DTYP, "Snmp")
  field(SCAN, "5 second")
  field(INP,  "@$(HOST) $(COMMUNITY) $(MIB)::mbgLtNgRefclockState Integer: 10")
Where:
$(HOST) = 192.168.XXX.XXX – this is of course fake address
$(COMMUNITY) = -c comm
$(MIB) = MBG-SNMP-LTNG-MIB
But I got error:
devSnmp: error parsing '192.168.XXX.XXX -c comm MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState Integer: 10'
         format is 'host community oidname mask maxdatalength [set_format/special]'
Error (511,511) PV: P:R:RefclockState devSnmpLi (init_record) bad parameters
Any help how I can do this?
Best regards
Tomasz Brys
European Spallation Source ERIC
Re: SNMP in EPICS Priller, John via Tech-talk
Re: SNMP in EPICS Pierrick M Hanlet via Tech-talk
Re: SNMP in EPICS Dunning, Michael via Tech-talk
Prev: RE: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Next: Re: SNMP in EPICS Priller, John via Tech-talk
Prev: Re: Modbus & asynManager::queueLockPort queueRequest failed: port not connected Mark Rivers via Tech-talk
