Subject: Re: SNMP in EPICS
From: "Dunning, Michael via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Tomasz Brys <[email protected]>
Date: Fri, 21 May 2021 15:54:15 +0000
> I want to keep MIB file somewhere in the module, not in the /usr/share/snmp directory.
If you're using the NSCL SNMP support, you can add directories to the
MIB search path by setting the MIBDIRS environment variable in your
IOC startup script, like this:
epicsEnvSet("MIBDIRS", "+$(TOP)/mibs:/some/other/directory")
In this case $(TOP) is the top directory of the IOC application.
This is described here:
https://groups.nscl.msu.edu/controls/files/devSnmp.html#MIBfiles
Michael Dunning
SLAC National Accelerator Laboratory
2575 Sand Hill Road
Menlo Park, CA 94025
(650) 926-5200
From: Tech-talk <[email protected]> on behalf of Tomasz Brys via Tech-talk <[email protected]>
Sent: Friday, May 21, 2021 1:13 AM
To: [email protected] <[email protected]>
Subject: SNMP in EPICS
I have a problem how to implement SNMP protocol in EPICS.
If I run snmpwalk I can:
snmpwalk -v2c -M +/vagrant/modules/e3-M300_GPS/M300_GPS/M300_GPSApp/MBG-SNMP-MIB -m All -c comm 192.168.XXX.XXX MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState
and I get output:
MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState.1 = INTEGER: synchronized(1)
How should I define my record in Db?
I did it like that:
record(longin, "$(P)$(R)RefclockState"){
  field(DESC, "Status of GPS refclock")
  field(DTYP, "Snmp")
  field(SCAN, "5 second")
  field(INP,  "@$(HOST) $(COMMUNITY) $(MIB)::mbgLtNgRefclockState Integer: 10")
Where:
$(HOST) = 192.168.XXX.XXX – this is of course fake address
$(COMMUNITY) = -c comm
$(MIB) = MBG-SNMP-LTNG-MIB
But I got error:
devSnmp: error parsing '192.168.XXX.XXX -c comm MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState Integer: 10'
         format is 'host community oidname mask maxdatalength [set_format/special]'
Error (511,511) PV: P:R:RefclockState devSnmpLi (init_record) bad parameters
Any help how I can do this?
Best regards
Tomasz Brys
European Spallation Source ERIC
SNMP in EPICS Tomasz Brys via Tech-talk
Prev: Re: SNMP in EPICS Pierrick M Hanlet via Tech-talk
Next: Re: SNMP in EPICS Tomasz Brys via Tech-talk
Prev: Re: SNMP in EPICS Miroslaw Dach via Tech-talk
Next: caRepeater w/ systemd? Michael Davidsaver via Tech-talk
